0 Members and 1 Guest are viewing this topic. Read 12111 times.
Don't worry about shielding, don't worry about litz.If using four separate wires: The usual braiding technique is a simple two strand winding (do not "twist" wires like with a drill) at each earcup, and join into a 4-strand round braid down below. Lots of videos online on how to do the braid, but don't pull the wires too tight or bend them sharply. If you buy wire that has two conductors each, it's even easier and practically no braiding required. Send a single wire to each cup and simply twist down below; hold the top of the twist together with some glue/tape/heatshrink or buy a splitter.
Why even braid at all? What's the benefit? Seems like a lot of extra work....
Any recommended gauge or combined gauge w/ the braid? Thanks -
Adding extra work is the main idea.It may add better handling, flexibility and robustness.As to audible differences between braided and twisted. There are none.
It improves the spatial relationship between signal and ground wires, sounds significantly better.
Thanks for replying! I thought about litz, but I thought that the point of OCC wire is to remove the grain in the copper wire. Isn't going stranded just re-introducing that grain and thus negating the advantage of the OCC process?
