will these work as subs?
0 Members and 1 Guest are viewing this topic. Read 2310 times.
AUDFILE74
« on: 15 Dec 2016, 02:19 am »
i'm in the process of gathering gear for my first ob adventure. i am gonna do a 2way with bass. thinking of using these for the low end. i happen to have a pair  in my stash
http://dls.se/en/car/prod.html?produkt=en_1259
here are the specs
OA10D is a 10" subwoofer in Performance open air series.
- Paper cone with foam surround and dual spiders.
- Powerful dual magnet system.
- Can also be used in vented enclosures.
- Complete your installation with the RG10 grille (not included).
   Specifications
Woofer size   10" (25 cm)
Impedance   4 ohm
Power handling capacity   180 W RMS
Max power handling capacity   360 W
Peak power   500 W
Frequency range   25-2000 Hz
Sensitivity   86,5 dB (1W/1m)
Magnet size   145 mm (5,7"), 80 oz
Outer diameter of woofer   270 mm (10,63")
Mounting depth   153 mm ( 6,02")
Mounting hole   240 mm (9,45")
X-max   +- 9 mm (0,35")
Weight   5,5 kg / 12,13 lb
T/S parameters
single V/C
Fs    39,9    Hz     Re    3,59    Ohm     Qms    3,19
Vas    25,5    liter     Vas    0,6    Cuft     Qes    0,55
Qts    0,47        Sd    314,6    cm²     BL    11,96
mcgsxr
Re: will these work as subs?
« Reply #1 on: 15 Dec 2016, 12:53 pm »
It can work.
FS is low enough.
QTS is getting closer to 0.7 (some say the ideal value).
XMAX is close to good too - more is almost always better for an OB woofer.
Do you intend to biamp the woofers or is it a passive setup with the wide range driver?
« Reply #2 on: 15 Dec 2016, 01:17 pm »
It can work.
FS is low enough.
I sew QTS=0,47
T/S parameters
single V/C
ThePriest
  • 101010 = 2A
« Reply #3 on: 15 Dec 2016, 01:44 pm »
I think most of the data looks OK, but the sensitivity is quite low, with only 86,5dB.
You will probably need a separate amplifier for the bass, to adjust for the sensitivity.
/ThePriest
JCS
« Reply #4 on: 15 Dec 2016, 05:25 pm »
I have only built one pair of OBs, so take my opinion w/ a grain of salt (or two).  I made a slightly modified version of MJK’s passive 2-way using Fostex FF85k (no longer available) and Eminence Alpha 15a.  I like them very much & use them daily.
If you are curious, take a look at:
http://www.quarter-wave.com/OBs/OB_Theory.html
Looking at your driver: I think the Qts is too low.  Using a 20”w x 40” tall baffle w/ driver centered 10” from bottom, I think you will get 86 dB for 2.83v input; F10 about 44 Hz.  Might want to use EQ on it, but then you are putting the driver at risk unless you keep it down to very modest SPLs.  I would use a 200 Hz low pass & a 40 Hz high pass (to limit excursion).  Using 2 drivers will get you additional output; however, unless you have an amp that is stable at 2 ohms, you would need to run them in series, making the XO parts more expensive.  So maybe a miniDSP would be cheaper—you might want to use 2 amps anyway to match levels from the woofer & mid/tweeter.
Remember (or maybe you already know): the acoustic XO point and the electrical XO point for OBs are NOT the same.  Again, check out MJK’s site.
Keep us posted!
« Reply #5 on: 16 Dec 2016, 05:37 am »
/ThePriest
Add to it the bass freq have an decreasing of 4 to 5db when in OB.
AUDFILE74
« Reply #6 on: 16 Dec 2016, 07:41 am »
yes,
i plan to run an amp on the woofer
It can work.
FS is low enough.
AUDFILE74
« Reply #7 on: 17 Dec 2016, 09:46 am »
