Remote code for DAC9?
0 Members and 1 Guest are viewing this topic. Read 3902 times.
lousyreeds1
« on: 11 Dec 2016, 06:44 pm »
Hi all,
Does anyone have the IR remote code for the DAC-9?  I'm trying to use a universal remote with this.
Many thanks,
Oliver
lousyreeds1
Re: Remote code for DAC9?
« Reply #1 on: 14 Dec 2016, 01:10 pm »
Any information, even confirmation as to whether the DAC-9 can be controlled by a universal remote, would be appreciated.  As seems to often be the case, the support service isn't working.
Oliver
mcgsxr
« Reply #2 on: 14 Dec 2016, 02:28 pm »
I cannot speak specifically to the DAC9.
My Logitech was super easy to configure to control my AVP-16.  I would be surprised if NuForce used different codes for different gear.
What universal remote are you considering using?
lousyreeds1
« Reply #3 on: 14 Dec 2016, 02:42 pm »
Thanks.  I'm using the xbox one remote.  If you have an IR code for other NuPrime equipment I'd appreciate having it!  I found a long list of discrete codes on the website, but no general use code.  Apologies if I missed something.
mcgsxr
« Reply #4 on: 14 Dec 2016, 05:16 pm »
I won't have the discrete codes, my Logitech Harmony does not require that I need them.  I simply went online, chose NuForce from a list of gear, and when I updated my remote, it just works.
Sorry.
lousyreeds1
« Reply #5 on: 15 Dec 2016, 06:07 pm »
The xbox has NuForce settings available, but none of the codes work.  Any help, including from tech support, would be welcome.
rustydoglim
« Reply #6 on: 18 Dec 2016, 09:59 am »
I will get all the remote codes published next week.
lousyreeds1
« Reply #7 on: 23 Dec 2016, 11:24 pm »
Thanks.  Can you point me to the link?  I don't see anything on the website.
rustydoglim
« Reply #8 on: 27 Dec 2016, 04:28 pm »
Here's codes for several models. We will clean up the format and post to the website later, but here's for anyone who need them now.
IDA-6
NEC Key
CUSTOM CODE 00FF
KEY CODE---------------------
0x01  POWER
0x0C  CHANNEL UP
0x0A  CHANNEL DOWN
0x0D  A1
0x0E  O3
0x06  C5
0x00  MUTE
0x09  VOLUME UP
0x15  VOLUME DOWN
0x16  E2
0x14  O4
0x08  C6
IDA-8
NEC Key
CUSTOM CODE 0x40
0x4d POWER
0x0d MUTE
0x0b VOLUME UP
0x0e VOLUME DOWN
0x11 CHANNEL UP
0x10 CHANNEL DOWN
0x42 C1
0x45 O2
0x1a U3
0x4a E4
0x4b A5
0x4c DISPLAY OFF
DAC-9
NEC Key
CUSTOM CODE 0x40
0x4d POWER
0x0d MUTE
0x0b VOLUME UP
0x0e VOLUME DOWN
0x11 CHANNEL UP
0x10 CHANNEL DOWN
0x42 C1
0x45 O2
0x1a U3
0x4a E4
0x4b A5/AE
0x4c DISPLAY OFF
IDA-16
000Eh // POWER ON/OFF
0010h // AUX
0004h // USB
001Ch // COAX1
0000h // COAX2
0002h // OPT1
0003h // OPT2
0006h // MUTE
000Ch // VOLUME UP
0005h // VOLUME DOWN
DAC-10
0010h // L1/L2
0004h // USB
001Ch // COAX1
0000h // COAX2
0002h // OPT1
0003h // OPT2
0006h // MUTE
000Ch // VOLUME UP
MCH-K38
000Eh // POWER ON
0010h // POWER OFF
0004h // CH 1
001Ch // CH 2
0000h // CH 3
0002h // CH 4
0003h // CH 5
0006h // CH 6
000Ch // CH 7
0005h // CH 8
lousyreeds1
« Reply #9 on: 29 Dec 2016, 09:30 pm »
Thanks.  The xbox doesn't recognize the "custom code" of 0x40 for the DAC-9.  Can you recommend trying anything else, or does this just mean the xbox can't control the DAC-9?  Too bad...
