NAS Newbie--moving movies to hard drive
0 Members and 1 Guest are viewing this topic. Read 2048 times.
matthewpartrick
  • vinnierossiforum.com
    • The Clueless Audiophile
« on: 26 Nov 2016, 03:13 pm »
Haven't bought the NAS yet, leaning towards Synology.  I have a bunch of 1TB usb drives lying around; can I use a program to load my movies onto this before I get the NAS (maybe xmas gift) or is it a waste of time?
Thx
PS. I've got the audio files covered already! :)
jtwrace
    • TIPP YouTube Channel
Re: NAS Newbie--moving movies to hard drive
« Reply #1 on: 26 Nov 2016, 03:26 pm »
No. all drives need to be configured once installed on the nas.
jonbee
« Reply #2 on: 26 Nov 2016, 04:46 pm »
That's correct. You can load them onto a drive that you are not planning to use in the NAS, then transfer them to the NAS using usb or network connections if that helps.
matthewpartrick
« Reply #3 on: 26 Nov 2016, 06:06 pm »
But, for whatever format the DVD will be in, that won't change, correct?  So I could theoretically put them on the USB drive and then transfer them to the NAS when it's set up?
jtwrace
« Reply #4 on: 26 Nov 2016, 06:23 pm »
Yes. Get a hard drive reader (toaster) and you can plug all drives into it and transfer.  Very simple.
matthewpartrick
« Reply #5 on: 26 Nov 2016, 06:46 pm »
I reripped all my music files in FLAC about two years ago, but have never done this for DVD.  Is there a specific program you recommend or would it come with the hardware?
ctviggen
« Reply #6 on: 26 Nov 2016, 10:38 pm »
DVDs are encrypted and you need to remove the copy protection.  Usually you also need a program like DVD Shrink, which puts the DVD into basically a software copy.
jonbee
« Reply #7 on: 27 Nov 2016, 03:01 am »
Makemkv.com software rips to an uncompressed mkv file, bypassing copy protection. You can use other software to reformat the mkv if you wish, or just play them as is.
« Last Edit: 27 Nov 2016, 03:53 pm by jonbee »
