6N1 and 6P15 tubes
0 Members and 1 Guest are viewing this topic. Read 10180 times.
Druter
6N1 and 6P15 tubes
« on: 22 Nov 2016, 12:09 am »
Hello, I just bought the monoprice Hybrid tube amp, as it was all I could really afford right at this moment in time. After doing a lot of research into tubes and tube amps I settled on this as I am just starting out. One thing I am very interested in is tube rolling. This unit uses two 6N1 and two 6N15 tubes. I believe these are chinese tubes and pretty much the base models. From what I have been reading I can't find replacement tubes to start tube rolling. Can anyone recoomend equivilent tubes from golden lion or even electro-harmonix? Also does anyone know  a good place to buy said equvalent tubes. I have searched the tubestore.com and tubedepot.com without much luck.
Any help is greatly appreciated
Phil A
Re: 6N1 and 6P15 tubes
« Reply #1 on: 22 Nov 2016, 01:58 am »
Welcome to AC!
Phil A
« Reply #2 on: 22 Nov 2016, 01:59 am »
Don't know if this helps but there may be similar sites - http://www.worldtubecompany.com/mm5/merchant.mvc?Screen=TSL
« Reply #4 on: 22 Nov 2016, 02:30 am »
Welcome  :thumb:
6N1 is the Sino version from the Russian 6N1P(6H1n):
http://www.gstube.com/catalog/?key=6n1p&bl=&mmm=0&aaa=0&valuta=840
Which is a direct plug-in replacement for 6DJ8 ECC88 6922 etc in most audio applications.
Avoid the 6H1n-Bi (impulse).
« Last Edit: 22 Nov 2016, 04:49 am by FullRangeMan »
« Reply #5 on: 22 Nov 2016, 04:11 am »
So there is other versions compatible:
6N1P warmest tone,
6N2P more gain,
6922 best dynamics,
6H30 a super 6922,
6DJ8 most air and micro-detail with a touch less bass,
7DJ8 7V version.
6P15P-EV unparalleled in speed and detail, wide bandwith video tube, best sound and transparent EL84 version by a mile.
EL84(6BQ5) warmer sounding.
Ask for 6n15n-EP matched a bargain at $3.70, very good seller:
http://www.gstube.com/catalog/?key=6p15&submit=Find
