0 Members and 1 Guest are viewing this topic. Read 15740 times.
I've also heard several of Steve's speakers... Weak bass seemed to be his taste, typical of the small amp/high efficiency crowd.
Seems like Rex is the consummate SET/single driver fan. To each their own. My mains are single driver designs too, but rated F3 = 27 Hz (but aren't efficient enough for SETs). You don't need to turn up the volume to hear deep bass. Perhaps you've been without deep bass for so long you've forgotten. Many of my single driver buddies almost freak out when they heard musical/deep bass from my speakers, like they can't believe it's real.And I'm with O.B., you don't need a 32 foot long room to hear 16 Hz, which BTW is 70 feet long (1120 fps/16 Hz). By that logical I wouldn't be able to hear below 53 Hz in my 21 foot long room and I know that's wrong. What you were hearing was probably standing waves that exist in every residential sized room.
Typical? Really?
Rex has owned a lot of SET amps, but he is not a SET fan.If you do not have a 32 foot pipe on an organ, it will not produce 16hz notes. And if you sit too close to the organ, you will not hear the 16hz notes. Show me another C&C speaker that produces 20 hz bass. The Decware DNA horn is rated to 20hz. But I am sure Rex's room is to small for that response. DNA HornSingle Point SourceCrossover-less20Hz ~ 20kHz!Ultra SMOOTH frequency responseFAST recoveryLow Phase AngleWorld Class ImagingBenchmark FidelityBi-Polar with decayed rear wave response 6dB/octaveEasy Impedance of 7 to 70 ohms / 20Hz~20KHz
anyone here using the "entry" level Hawthorne Audio OB's? (15 inchers(I have them and they do a pretty damn good job on most of my music with a t amp and Tidal via usb dac.
DIY is "cheating" the C&C guidelines. The DNA speakers retail for $1700/pair. And I seriously doubt they really reach 23 Hz as advertised. Again, nearly all small amp/efficient speaker fans I know don't know what 30 Hz sounds like.
I would also like to encourage DIY crowd and those with well of information on projects which will be appropriate for this Circle to step forward and offer their knowledge.
Cheating? Did you read the guidelines?
JLM is quite correct in his characterization of most single driver systems, ......................... I'm not sure why anyone would argue those points, especially with anecdotal arguments.I doubt single driver enthusiasts are so inclined for bass responce in any case.
Oops. I'm truly surprised that DIY is allowed.
I'm unwilling to do a peer reviewed study to satisfy you, but most of the single driver fans that I know and read about have some sort of bass augmentation in their "single driver systems".
