SOLD: 100W Linear Power Supply $270
0 Members and 1 Guest are viewing this topic. Read 691 times.
robertsong9
« on: 16 Nov 2016, 04:25 pm »
Brand new factory replacement with cables. Replaced with a different LPS. Great sounding LPS that can power 4 different devices. $395 retail. 3 year warranty (2 years left).
Paypal "Friends and Family" greatly appreciated, but that's up to you.
 Technical Specifications:
Wattage    100W (Max 160W)
Feature    Top of the Line Hi-End Audio ELNA Capacitors
High Quality 160W Silent R-Core Transformer provides clean energy
No Humming or Buzz noise for 50Hz and Peak load, 100% Silent
Linear Technology LT1083 Low Dropout Positive Fixed Regulators
Low ripple noise and void of high frequency noise
19V/8AMP Output is User Ajdustable from 15V-19V via XLR Connector, Supprt Thin ITX/NUC/Auralic Aries Mini/HDPLEX 250W DC-ATX Converter
12V/8AMP Output via XLR Connector, support Legacy Wavelet DAC/Qnap Nas/PicoPSU or 12V based CE device.
5V-19.5V/3AMP User Adjustalbe Output support SoTM PCIE USB card/MicroRendu/Upton USB Regen.
5V/3AMP Output support PPA (Paul Professional Audio) USB Audio card and Squeezebox.
USB 3.1 Type C 5V Output
Passive aluminum chassis guarantee absolute silent and stable operation
Chassis Material/Color: Brushed Aluminum/ All Black
Power Indicator: Yes (Blue LED via Face Plate LED Port)
Power ON/OFF Switch: Yes (On the Back Plate )
Operating Temperature: -10C - 70C
Safety: Overvoltage Protection(OVP), Undervoltage Protection(UVP), Overcurrent Protection(OCP), Short Circuit Protection
Certification:
CE/EN60950-1 (TCT1405072566S-1)
RoHS (TCT1405074557R-1)
FCC (TCT1405074391F-1)
EMC (TCT1405073270E-1)
Certification and official ripple test report download here.
Idle Power Consumption: < 4W
Size:250(L) x 180 (W) x 70 (H) mm
Weight:6kg/13 lbs
Input Voltage: 110V/240V AC (MAX 260V AC)
AC Input Connector: IEC with EMI Filter
DC Output:19V/12V XLR---Aerospace GX16-2/7.4x5.0mm/5.5x2.5mm/5.5x2.1mm Connector
DC Output:9V/5V Aerospace GX16-2---5.5x2.5mm/5.5x2.1mm/Molex 4PIN (For PPA Card) Connector
« Last Edit: 21 Nov 2016, 07:07 pm by robertsong9 »
sonicxtc
Re: FS: New HDPLEX 100W Linear Power Supply $270
« Reply #1 on: 16 Nov 2016, 08:29 pm »
PM Sent
