0 Members and 1 Guest are viewing this topic. Read 16333 times.
My recommendation would be to use the same cable Louis used to wire your speakers: the Supra Classic 2.5. https://www.madisoundspeakerstore.com/speaker-wire/supra-classic-2.5-speaker-wire-per-foot-13-awg/It's $1.68/foot, and you won't need to terminate it if you don want to. An 8-foot pair should cost you less than $50 including shipping.If you really want to terminate it, I would investigate using something very light, such as Danny's Tube Connectors or ETI/Eichman plugs. Frankly, I would do bare wire unless you are changing cables with some frequency.
How about the Kimber 4PR?
The Nak banana plugs are great - I've used them alot. Another great option is the QED Profile 79 strand wire with their cold welded bananas or spades. When using an amp with top speaker terminals like a Decware I like to use spades at the amp end (for a more tidy look) and bananas at the speakers.
Supra makes great banana plugs as well. They can be configured inline or at 90 degrees. The run about $100 for four pair, enough for one set of cables. Of course, it rubs me the wrong way to spend twice as much on connectors as the cable itself, especially when the connector may actually degrade the cable performance.In the case of the Supra cable, the conductors are tin-plated copper and won't suffer from exposure to air like unplated copper or silver cables. If I were using cable that required sealing (such as Neotech braid) I would want a connector with a gas-tight connection, sealed with solder.
