Etesian and powerchord?
0 Members and 1 Guest are viewing this topic. Read 1251 times.
RooX
« on: 18 Nov 2004, 05:09 pm »
Hey all,
Does anyone have any experience swapping power chords on the etesian?  my initial thoght would be that it makes little to no difference, being that its a passive pre.
BUT.
this is audio, and you never know.
i owuld love some reccomendations if anyone has any.
(ps, yes this means i took the plunge for an etesian, im a first time odyssey owner now! :) )
alex_odyssey_sg
    • http://www.odysseyaudiosg.com
Re: Etesian and powerchord?
« Reply #1 on: 22 Nov 2004, 09:48 am »
Hi,
I've tried the Groneberg, Siltech and stock cable. Honestly, if there is a difference...I cannot tell. Anyway, the transformer is just for the relay and does not interfere with the signal path at all.
During the show, there was a request to switch 2 CDPs (Rega Planet and Xindak SCD2) on the Etesian. You should heard how transparent the Etesian is...the 2 CDP sounds so different. On other systems, the difference would probably be not as wide.
