SET vs. Push-Pull
0 Members and 1 Guest are viewing this topic. Read 2428 times.
bigdaddysteve
SET vs. Push-Pull
« on: 11 Nov 2016, 02:27 am »
I am very interest in moving from solid state to tubes and wanted the pros and cons of going with a SET amp vs. Push-pull amp.
Re: SET vs. Push-Pull
« Reply #1 on: 11 Nov 2016, 02:48 am »
Welcome Bigdaddysteve :thumb:
SET amps were the first amps made in 1930s, they are plain simple more simpler than PP, few parts. According the great Gizmo after 10W tube amps become more complex, more parts, more expensive etc
SET amps have best sound than PP due just 1 output tube and few parts, fewer joint solders etc
Decware built philosophy also apply here.
You may choose tubes according your Watts requirements:
300B 7W (a expensive tube)
EL34 7W  (in Triode)
KT150 20W (in Triode, expensive)
6C33 13 to 15W
GM70 25W
All conservative SET projects, forget 211 845 805 they are expensive tubes and cant reach GM70.
« Last Edit: 11 Nov 2016, 04:04 am by FullRangeMan »
« Reply #2 on: 11 Nov 2016, 05:17 am »
Greetings & Welcome to AC bigdaddysteve   :thumb:
brooklyn
« Reply #3 on: 11 Nov 2016, 05:43 am »
jarcher
  • It Just Sounds Right
« Reply #4 on: 11 Nov 2016, 05:46 am »
Welcome!
Suggest you read this - short and informative :
http://www.theabsolutesound.com/articles/a-survey-of-amplifier-types-tas-217-1/
G Georgopoulos
« Reply #5 on: 11 Nov 2016, 06:16 am »
to be truethfull, i don't know, i thought both are equal... :green:
Phil A
« Reply #6 on: 11 Nov 2016, 12:26 pm »
Welcome!
