0 Members and 1 Guest are viewing this topic. Read 3185 times.
I'm positive the power supply is much better, I know the binding posts are superior, and HK's are known for delivering much more power than they're rated, especially when compared against other like models. I believe each channel has its own power supply. The HK will blow the Panny away in terms of shear power. HK's ratings are underrated with all channels driven. I was thinking about buying one of the Panny's, but when you add the mods that need to be done to address the power issues, spending a couple hundred more on the HK doesn't seem that crazy.
If you have a 45, I'd love to hear how you think the HK compares. I don't have a Panny to compare the HK to, but was thinking of loaning one from my local Circuit City. Since you can do a direct comparison, you might save me some trouble.
Yes. I will drop by my local Circuit City tomorrow to see if they can let me have a "loaner" for a week or so. I don't see why not.
