IDA-16 : Discrete IR Codes (On/off & mute)
0 Members and 1 Guest are viewing this topic. Read 1979 times.
chrisoff
« on: 6 Nov 2016, 10:27 am »
I'm currently using iTach IP2IR from Global Cache for the control of my units (TV, sound projector, sources, IDA-16 preamp).
It works very well and I'm happy with the solution. I was able to learn all the IR codes of IDA-16 remote controller.
However currently I only have "toggle on/off" and "toggle mute" functionality.
This is not convenient for my application I would rather have one button for "on" another for "off".
(And the same for mute functionality)
Do you have a couple of Discrete IR Codes available that may allow me to create those "virtual" buttons ?
Chris'Off
chrisoff
Re: IDA-16 : Discrete IR Codes (On/off & mute)
« Reply #1 on: 19 Nov 2016, 08:10 am »
No one has the same kind of IR control ?
27Kcd
« Reply #2 on: 6 Mar 2020, 03:15 pm »
I bought a Logitech Harmony 665 before my IDA-16 has even arrived.
