FS: Hypex UCD180HG Amplifier with HxR Regulators *** SOLD ****
0 Members and 1 Guest are viewing this topic. Read 5009 times.
Nick77
I'm selling my Hypex UCD180HG Amplifier with upgraded HxR regulators. This is the latest High Grade series  module with upgraded HxR regulators and has trickle down technology from the Hypex Ncore modules.
I built this a couple years ago using premium parts:
Wired with Cardas Litz hookup wire, both the power supply and signal cable and speaker wires.  ( http://www.cardas.com/litz.php )
Cardas CPBP copper binding posts
CMC Red Copper RCA
Premium copper IEC
Oyaide copper faston power connectors
Create Audio Nano Fuse
Rocker power switch on back
Beautiful Walnut grain front panel and repurposed metal case, rated 6/10 for diy nature.
90 watts per channel into 8ohm. Sound is very resolute and dynamic, with excellent bass. The Cardas wire made a big difference in sound signature, stock wire sounded a little flat. Owned a ClassD Audio SDS series prior to the Hypex, the UCD180 is far superior.
The Power supply was also recapped using recommended caps (Nichicon and Panasonic) from DiyAudio thread increasing capacitance, nice increase in dynamics. Modules attached to aluminum heat sinks. Dual mono modules, for 2 channels with Hypex power supply. These same modules are used in many $$$ commercial amp offerings. These new UCD series amps come surprisingly close to the Ncore performance for a fraction of cost.
Looking to gauge interest, lowered to $375 plus shipping and paypal    Lowered price!
Pics coming soon.  Local audition welcome.
« Last Edit: 17 Nov 2016, 06:05 pm by Nick77 »
I unknow you was a builder, congrats :thumb:
vkaiwar
Is this a one-off or are you planning to build some more?
Nick77
Just a one off personal build. Thks.....
Nick77
Re: IC: Hypex UCD180HG Amplifier with HxR Regulators $400
« Reply #4 on: 7 Nov 2016, 11:55 am »
Price lowered, any interest at $400??  :scratch:
Pretty amazing sound quality at this price of entry. Plenty of reviews.
HYPEX UCD 180 HG HxR
What do you look for in a power amplifier? Bet it's the sound. Hypex UcD amplifier modules are designed from the ground up for true fidelity. Available in 180W, 400W and 700W variants, they represent a new generation of switching power converters truly performing as amplifiers.
Features
Flat, fully load-independentfrequency response
Low output impedance
Very low, frequency-independent THD
Very low noise
Consistent top performer in listening trials including class Aand SET amplifiers
Runs on unregulated +/- rails
Pop-free start and stop control
Differential audio input
Overcurrent, shortcurrent and over voltage
DC/AC-coupling selectable
Fits in a 2HE case when mounted on its side
4-layer PCB design
HxR regulator ready
Applications
Monitor loudspeakers for recording and mastering studios
Audiophile power amplifiers for professional and consumer use
Public Address systems
Home theatre systems
Active loudspeakers
Technology
The UcD circuit is based on phase-shift controlled self-oscillation, with only a single voltage feedback control loop taking off at the loudspeaker terminals. The control function is constructed fully out of passive components, with only the comparator standing in for gain.
Output Power PR 180W 4OHM, THD=1%
Distortion THD < 0.1% typ Po<600W
Distortion THD < 0.008% typ Po=1W
Noise Un 30uV typ
Frequency Response < 10Hz-50kHz +0,-3dB
Output Impedance Zo < 20 mOhm f=1kHz
Output Impedance Zo < 150 mOhm f=20kHz
Efficiency n > 92%
Supply Ripple Rejection PSRR 65dB Both rails
With pre-mounted HxR regulators
Description
The HPR12/HNR12 are high performance voltage regulators targeted at performance-critical audio applications. Key performance parameters exceed that of industry-standard integrated circuits by several orders of magnitude. Kelvin sense connections provide point-of-load (local) regulation with- out requiring physical proximity.
Features
Ultra-low noise
Wide bandwidth
Excellent ripple rejection
Low, load-independent output impedance
Size and pin compatible with TO-220 style regulators
Applications
Preamplifiers and buffers
RIAA input stages
Playback head amplifiers
Performance upgrade for existing products
Nick77
Re: IC: Hypex UCD180HG Amplifier with HxR Regulators $375
« Reply #5 on: 10 Nov 2016, 12:35 pm »
Lower price, these new UCD modules come really close to Ncore at a fraction of the cost.
I replaced Alder faceplate with a beautiful Walnut faceplate.
« Last Edit: 11 Nov 2016, 11:10 pm by Nick77 »
jtwrace
    • TIPP YouTube Channel
« Reply #6 on: 10 Nov 2016, 03:30 pm »
I'm shocked at this price these are still available.  To get this level of performance for this cost is insane.  Even if you purchased these as a backup amp or a garage system you will not be disappointed.  Why you're selling this in the first place I don't know.   :P
Nick77
« Reply #7 on: 10 Nov 2016, 04:12 pm »
.          jT I couldn't agree more, thanks for the input. Only selling to fund new diy build. Certainly having second thoughts as much as I desire a new project.
Nick77
« Reply #8 on: 11 Nov 2016, 10:40 pm »
Bump for pictures of beautiful walnut face plate.
fiveoclockfriday
Hi there, I have a couple quick questions.
Does this include the power supply? Assuming not, is there a good reference for what you should use?
Similarly, I couldn't find specs (in my quick searching) on idle power consumption. Looks like this is meant to be left on, so I'm just trying to figure that out.
Eric B.
Nick77
Eric B.
Hi Eric this is a complete amplifier with the corresponding Hypex power supply SMPS400A180 for UCD180 modules. Im not sure of idle consumption but the modules remain in a standby mode when powered off so Im sure its pretty low. The power switch is on the rear of amp which powers up off of standby and engages the speaker connection. So they remain partially powered on in a standby mode if you use the on/off switch.
I have always powered them down into standby cause the amp only gets used on weekends.
Specifications.........
http://www.hypex.nl/docs/UcD180HG_datasheet.pdf
Keith
Carl V
PM sent
