ER Audio 505 ESL Array/Altec 416 midwoofer/Rythmik sub
0 Members and 1 Guest are viewing this topic. Read 3723 times.
bellicon
I would really appreciate some timely feedback to risk proceeding with my little ESL fantasy, albeit via the back door.
As I have insufficient knowledge (and especially the time) to do much DIYing, Jim Salk
http://www.salksound.com/ is cloning Gary Dahl’s BTA speakers for me (minus the RAAL ribbons, which Gary no longer uses since he switched from his Lundahl transformer coupled 300B p-p amps to Gary Pimm’s vastly upgraded Tabor solid-state amp) http://www.diyaudio.com/forums/multi-way/100392-beyond-ariel-1295.html
Jim should have them finished around February. But before he ships them I thought about how the ER Audio 505 panels would work above each GPA Altec 416-8B midwoofer. http://www.eraudio.com.au/Mini_Panels/mini_panels.html
http://www.greatplainsaudio.com/downloads/416-8B%20Spec%20Sheet.pdf
I’m certainly no expert, but by using two or three 505 panels above each 416 midwoofer, would not soundstage for the highs and upper mids greatly improve in all three dimensions?
As for the critical midrange, Gary passively crosses the (equalized) Azurahorn/Radian driver combo with the Altecs to have the latter begin playing at 700Hz.
The GPA Altec 416’s under hung voice coil keeps distortion low. And Gary has each midwoofer in sealed low diffraction cabinets, where the response goes down to only 70Hz, further minimizing distortion. A pair of Jim’s version of the Rythmik 12" sealed servo subs take over below this.
Whether I use Rob’s passive crossover or bi-amp the system with something like this http://www.firstwatt.com/pdf/prod_b4_man.pdf , would you expect the results to be comparable to those here? https://drive.google.com/file/d/0B1XTT_kQmJ_QNE1wbnVFdUsyLWs/view Note, however, the “milliwatt” typo in the specs. http://www.jblpro.com/pub/obsolete/4331a_4333a.pdf
At least some things have changed for the better. I am no longer limited to using the First Watt F4 amp, at least not alone. My room size will be either 12 ft x 15 or 14 ft x19, where, due to heat and clutter issues, I would either passively or actively cross the speakers, respectively.
As for bi-amping, I would drive the ~ 97db Altecs with either the F4 or my First Watt J2 (also 25 wpc/ 8 ohms), or sell off one for a really superb sounding Class AB amp.
But if bi-amping, and to drive the ESLs alone, how well would 300B SET monos work?
While they are noted for an awesome 3D soundstage and a magical midrange, don’t their highs roll off soon after 10kHz?
And as they are typically 9 wpc, how much output will they do at 10kHz, when each 505 panel’s impedance drops to 4 ohms? And down to 2 ohms at 20kHz, according to the curve here? http://www.eraudio.com.au/Mini_Panels/mini_panels.html
However, in terms of wpc vs. required SPLs, since my average listening levels would be ~ 60db at 1kHz, in a 14 ft x 19 room, at 200Hz they would be only ~73db, as per the 2003 curve https://en.wikipedia.org/wiki/Equal-loudness_contour
On the other hand, as caps in parallel are additive, wouldn’t impedance below 10kHz be approaching zero if I use 3 panels per side? How would the 300B’s output transformers handle that kind of load?
Otherwise, I’d hate giving up on 300B SET magic, but would an OLT tube amp be a much better choice to drive three of those 505 panels? Maybe something like this? http://www.lineartubeaudio.com/zotl-10/
Ultimately, however, as you are the guys with the heavy ESL design, building and in-use experience, please evaluate the feasibility of this particular hybrid speaker + subwoofers concept. If the consensus here does not total 80% or better likelihood for a really awesome sounding build, then there’s no point to risk spending the 505 mini panels, since I don’t think that ER Audio does refunds.
I’d probably go for a passively or actively crossed OB speaker project.
Looking forward to your replies.
Jazzman53
  • Jazzman's DIY Electrostatic Loudspeaker Page
    • Jazzman's Electrostatic Loudspeaker Page
Re: ER Audio 505 ESL Array/Altec 416 midwoofer/Rythmik sub
« Reply #1 on: 1 Nov 2016, 01:35 am »
Hi Bellicon,
I build ESL's myself but I can't advise you on the ER panels, as i am not familiar with them, and my experience is limited to large panel hybrid ESL' that use active crossovers.  I admire anyone who can design a passive crossover for an ESL-- I would have no idea how to do that or evaluate someone else's passive design.
This I can tell you though; a correctly designed ESL does not roll off at 10K.   At least ESL's which use 6 micron or thinner diaphragms do not roll off -- a 12 micron diaphragm does start rolling off around 12khz though.   Mine play to 20Khz and would go higher if the digital X-over I use didn't chop off the input at 20 Khz.  The step up transformer and panel capacitance also play a roll in the frequency response.  Bigger panels (higher capacitance) with high ratio transformers (>125:1, let's say) would roll off sooner than an ESL with a smaller panel and/or lower ratio transformer.
And, BTW, there are some really smart guys here but the real ESL gurus (I'm not one of them) reside at the DIY Audio Forum in the "planners & exotics" section.  If you really want good advice go there.  And if you receive any advice from "Golfnut", "Bolserst" or "Calvin", take it to heart because these are the REAL gurus in the DIY community.
bellicon
« Reply #2 on: 1 Nov 2016, 04:48 am »
Very helpful and much appreciated. Thanks.
BruceSB
« Reply #3 on: 1 Nov 2016, 08:43 pm »
Why not send Rob from ER Audio an email?
He is a super helpful guy as well as being very knowledgable.
I have sent him a few emails over the years and he is just great!!!
Bruce
bellicon
« Reply #4 on: 2 Nov 2016, 11:56 am »
I have and Rob was, very, and will again. But at some point I do wish that I could find someone in the NY area who would spit the cost a 505 panel experiment with me to try above my Altecs. I wish there was a US distributor for ERA ESLs panels.
ALSO! Please let me know if anyone has used 505 panels in open baffles. I thought of using them above a pair of AE OB15 woofers, possibly bi-amped.
http://aespeakers.com/shop/dipole/dipole15/
Manolo
  • Consulting Structural Engineer
« Reply #5 on: 4 Nov 2016, 07:43 pm »
Mick Maloney of Supratek Audio speaks highly of them. Go to his site and check his blog,where he has at least 2 articles on his diy designs and suggestions.
bellicon
« Reply #6 on: 5 Nov 2016, 02:04 pm »
Thanks Manolo, yes that's a wonderful blog he has. I was amazed by what he said about the long gone Acoustat 2+2. If it truly beat out some of today's big name ESLs it's surprising that Acoustat didn't survive.
Great stuff there about DACs too. Active crossovers yes, but unless one has lots of time and money to spend on building several equally high performance DACs, (and my source material is all digital), using digital crossovers gives me the willys.
