**SOLD**AV123 X-CS center in Palisander
0 Members and 1 Guest are viewing this topic. Read 2164 times.
Big Red Machine
« on: 30 Oct 2016, 07:53 pm »
I have a nice AV123 center channel with cloth grill. Original double box, cloth bag. There is some checking but no nasty splits in the veneer. Overall it looks like new from 3 feet away.
Tweeter intact but the cover will not cooperate and just bounce back no matter how hard I try.
$100 plus shipping at my discounted rate through work.
x-cs
    System: Two way, three driver direct-radiating system, sealed enclosure.
    Drivers: 1" treated fabric dome and two custom 6.5" curvilinear shaped treated paper cone woofers with polymer chassis
    Crossover: 2100Hz, 2nd order
    Frequency Response: 65 Hz to 20 KHz (± 3 dB)
    Impedance: 8 Ohms nominal
    Efficiency: 90.5 dB (@ 1 watt / 1 meter)
    Dimensions: 8.5" H x 20.0" W x 15.5" D
    Weight: 33 lbs each; ship weight = 41 lbs
« Last Edit: 10 Jan 2017, 06:57 pm by Big Red Machine »
Big Red Machine
Re: AV123 X-CS center in Palisander
« Reply #1 on: 17 Nov 2016, 11:41 am »
bump
Big Red Machine
« Reply #2 on: 26 Nov 2016, 05:45 pm »
bump
Big Red Machine
« Reply #3 on: 21 Dec 2016, 03:29 pm »
anybody?
sandbagger
« Reply #4 on: 24 Dec 2016, 06:29 pm »
I think I have a tweeter for it for free if it helps it sell
freerider
« Reply #5 on: 5 Jan 2017, 07:01 pm »
I'll take it with the new tweeter.  I need the cabinet to match my Palisander LS6's.  Right now, I have a GR Research upgraded X-CS center which is in a black cabinet.  I'll swap parts, and then I can use these parts, in my black box, for my new theater setup upstairs.  It should pair nicely with a my GR Research X-LS monitors that I have as spares.
freerider
« Reply #6 on: 10 Jan 2017, 04:44 am »
PM sent.
freerider
Re: **SOLD**AV123 X-CS center in Palisander
« Reply #7 on: 18 Jan 2017, 08:59 pm »
Received!  Looks awesome, sounds awesome!  Tweeter also looks perfect.  Guess it magically repaired itself?
