Songsurrounds1 and PowerPlay front-ported?
0 Members and 1 Guest are viewing this topic. Read 1329 times.
albireo13
« on: 26 Oct 2016, 03:45 pm »
I have been looking at these two speakers and notice a slit at the bottom in the front.  They are both ported speakers.
Does this mean they are front-ported?  I haven't been able to see any back-side views of these speakers.
Thx,
Rob
Big Red Machine
Re: Songsurrounds1 and PowerPlay front-ported?
« Reply #1 on: 26 Oct 2016, 04:55 pm »
Yes, front ports. Many times bookshelf speakers are given limited space so if you actually place them against a wall or bookshelf, then the port can do its thing.
albireo13
« Reply #2 on: 26 Oct 2016, 05:27 pm »
Awesome.  I was thinking of a wall-mount speaker instead of stands.
 :D
jsalk
« Reply #3 on: 26 Oct 2016, 09:25 pm »
Thx,
Rob
Rob -
Yes, if you see a slot on the bottom front of a speaker, it is front ported with a slot port.  If they are rear ported, you will not see this.
- Jim
