Constrained directivity OB Speakers
0 Members and 1 Guest are viewing this topic. Read 3085 times.
zydeco
« on: 23 Oct 2016, 04:20 pm »
I'm a fan of constrained directivity speakers and am wondering about open baffle versions of this concept. The default choice seems to be the Spatial Hologram M3 / 4 series which have received good reviews. It seems though as if Pure Audio Project has introduced something similar (albeit not a point source) with the Trio 15 Beyma (see http://www.pureaudioproject.com/product/trio15-beyma-tpl150-open-baffle-speakers/. Has anyone heard the Trio 15 Beyma and, if so, then what is the impression?
zydeco
Re: Constrained directivity OB Speakers
« Reply #1 on: 25 Oct 2016, 07:52 am »
Any one with experience of the PAP Trio 15 Beyma?
gils
« Reply #2 on: 25 Oct 2016, 10:18 pm »
Hello,
use HP QTS  > 0,8
Eminence 15A (trio) is QTS 1,26 ;)
http://petoindominique.fr/php/mysql_listehp4.php?marque=BEYMA
HP Good PLAN ( open baffle) is green ;)
not good 15 " Beyma , one 12" :)
Eminence 15 A "Trio"
http://petoindominique.fr/php/mysql_thiele_seul_ref.php?ref=ALPHA%2015%20A
Beyma just for tweeter
cdt.gils
« Last Edit: 6 Nov 2016, 11:31 pm by gils »
zydeco
« Reply #3 on: 26 Oct 2016, 07:02 am »
Hello,
use HP QTS  > 0,8
Beyma just for tweeter !!  :lol:
cdt.gils
Thanks but what does this mean?
mcgsxr
« Reply #4 on: 26 Oct 2016, 11:15 am »
It appears as advice to DIY something similar to the speaker you asked about.
I have never heard the Trio, but have read good things.  I have dealt with the Canadian distributor and can absolutely recommend Rachel at Grant Fidlelity.
zydeco
« Reply #5 on: 27 Feb 2017, 09:28 pm »
Still interested in a comparison of Spatial M3 Turbo and PAP Trio-15 150 or Horn-1. A key feature for me is constrained directivity. Any feedback?
