Unable to Load Music Folder in Roon
0 Members and 1 Guest are viewing this topic. Read 974 times.
Osadu
« on: 15 Oct 2016, 09:19 pm »
I have setup Roon in BDP-2.  I have my USB storage media containing my music attached to the BDP-2.  Under settings in Roon I go to Storage and when I try to add folders using into Network Folders, I use the BDP-2 IP address.  I type in
\\192.168.0.1\bryston\JazzMusic.
Where JazzMusic is the name of the folder.  The response I get is "The drive containing this media is not available or the folder has been deleted".  However, in MPD mode, the BDP-2 sees the music folder and plays music from this folder.  So I know the music folder is mounted and avaible to BDP-2.  What am I doing wrong in Roon?  Please help.
srb
Re: Unable to Load Music Folder in Roon
« Reply #1 on: 15 Oct 2016, 11:31 pm »
It seems a bit unusual (but not impossible) that in your 192.168.0 subnet that .1 would be the address of the BDP-2 and not that of your router or gateway.
Also, is "bryston" the root folder of the JazzMusic folder on your USB drive?
Osadu
« Reply #2 on: 17 Oct 2016, 01:29 am »
Problem solved.
srb
« Reply #3 on: 17 Oct 2016, 03:22 am »
It might be helpful to others (and to me) if you would share the solution.
