SOLD: Vandersteen VCC-1 Center Channel
0 Members and 1 Guest are viewing this topic. Read 1017 times.
Hear Clifford Brown
« on: 13 Oct 2016, 01:56 pm »
This is an excellent performing center channel speaker. I have one in my main system. This was in a second system and no longer needed. Wood finish is perfect and grill fabric has one barely noticeable hole about an eight inch in diameter.
$300, new these are $650.  Shipping is extra at actual cost, from 98424.  No charge for PayPal.  Box is 15 x 15 x 13 and shipping weight 26 pounds.
The VCC-1 is the only center speaker that incorporates integral design solutions to the specific center channel requirements. It is immune to lobing response variations and performs consistently at any height or positioning. It is magnetically shielded and can be compensated for any environment. It maintains the critical phase integrity of the original sound and fully complements the main speakers. As an important part of a high-fidelity home theater system, the VCC-1 folds seamlessly into the multi-channel soundfield. Whether reproducing a whisper or a shout; a breeze or a blizzard, it creates a realistic and totally involving experience.
The VCC-1's coaxial driver is a combination of a 6½ inch woofer and a 1 inch dome tweeter that share the same acoustical center and radiate as a single point source. The aligned driver is immune from multi-driver interference and the resulting response variations and phase irregularities that plague conventional center speakers. The VCC-1 maintains consistent sonic performance over an expansive listening area without hot spots, drop outs or timbre aberrations.
VCC-1 Specifications
Coaxial Woofer/Tweeter
6.5" Mineral-Filled Polycone with Die-Cast Basket with 1" Critically-Damped Alloy-Dome Tweeter
Recommended Amplification 30-200 Watts Into 8 Ohms
Frequency Response 80Hz -- 21kHz +/- 3dB
Sensitivity 86 dB, 1 meter with 2.83 volt input
Impedance 8 ohms nominal 5 ohms
Crossovers First order/6dB per octave, 3.5kHz
Input Terminals Barrier strips, 7/16" max width
Dimensions (WHD) 12 1/8" x 9 1/4" x 10 1/8"
Weight 23 lbs.
« Last Edit: 9 Dec 2016, 10:53 pm by Hear Clifford Brown »
Hear Clifford Brown
Re: Vandersteen VCC-1 Center Channel
« Reply #1 on: 16 Nov 2016, 05:47 pm »
bump
Hear Clifford Brown
« Reply #2 on: 28 Nov 2016, 05:34 am »
Bump
