Question
0 Members and 1 Guest are viewing this topic. Read 1255 times.
veloceleste
Question
« on: 11 Oct 2016, 11:02 pm »
« Last Edit: 22 Aug 2023, 07:57 pm by veloceleste »
  • The Demo is Everything!
    • http://www.bryston.com
Re: B60RPH Question
« Reply #1 on: 11 Oct 2016, 11:04 pm »
Hi,
I just purchased a B60RPH C series and I do not have turntable right now. However there is a 60hz hum when I output the phono section. I have completely isolated the unit, disconnecting all inputs as well as the speaker connections, listening only through the headphone jack with the B60 plugged directly into the wall.  I have tried several outlets on different circuits in the house with no change in the hum.  I was expecting a quiet, phono white/pink noise type sound through the phono input. Am I missing something or is there a problem with the unit. Thanks for any advice.
Hi
Do you have anything plugged into the Phono Section?
james
veloceleste
Re: B60RPH Question
« Reply #2 on: 11 Oct 2016, 11:13 pm »
No, nothing is plugged into any input.
veloceleste
Re: B60RPH Question
« Reply #3 on: 11 Oct 2016, 11:24 pm »
Hi James,
Thanks for the quick response.  Sorry for my curtness in the previous post!
Re: B60RPH Question
« Reply #4 on: 11 Oct 2016, 11:48 pm »
OK so i am thinking that without the ground the table would supply is the reason for the hum.
james
veloceleste
Re: B60RPH Question
« Reply #5 on: 12 Oct 2016, 12:23 am »
Hi,
I found an old pair of shorting plugs but one must be bad. I can eliminate the hum in one channel with the plugs in and when I switch plugs the hum stops in the other channel. Problem solved?  I'll have to get my hands on a turntable to confirm. Thanks for the guidance.
PS. I can't believe i found those old plugs! I can' t remember what I did 5 minutes ago. Priorities I guess. :D
