0 Members and 1 Guest are viewing this topic. Read 16325 times.
Do you have a tube tester?I have used the Shagung 274b in a Melody preamp and had no issues with the one I had. Cheap if you want to try one:http://www.thetubestore.com/Tubes/5U4-Tube-Types/Preferred-Series-274B-5U4GI prefer the Mullard 5AR4/GZ34 in some circuits, but as Syrah said in his post, tube rolling is very circuit dependent. Don't shy away from a used Mullard GZ34 as they have a life of 10,000 hours. I have been told the WE 422A is an excellent rectifier, but they are pricey.The 274b is a more lively tube in my experience and the Mullard GZ34 has a better mid range. My experience, but like all audio, it is a matter of opinion.Good luck with your search.
Thanks for the thoughtful replys. I'm going to call Andy Monday. I think it makes a lot of sense that certain tubes might not jive with certain circuits. Hopefully his extensive knowledge can guide me in the right direction based on what equipment I have and my specific sonic tastes. Dennis Had recommended the reissue gold lion gz34s. I'm curious to try a reissue versus a nice nos.
Decware suggestions seems usefull:http://www.decware.com/newsite/tubes.htmlThe rectifier location is compatible with 5U4G, 5AR4, 5Y3GT, and some 274B. Many owners of this amp like using the 274B however not all 274B tubes are completely compatible, so we ship the amp with one that we know IS.
Each rectifier change will also make audible differences in the sound and performance of the amplifier.[/b]
