SP3 Subwoofer Question
0 Members and 1 Guest are viewing this topic. Read 1281 times.
dminches
« on: 9 Oct 2016, 12:15 am »
Can I run 1 sub off the single-ended output and 1 sub off the balanced output at the same time?
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP3 Subwoofer Question
« Reply #1 on: 9 Oct 2016, 12:19 am »
Yes no problem.
james
JeffO
« Reply #2 on: 9 Oct 2016, 04:15 pm »
You can also use the menu to set the balanced R-AUX as a second sub output.
dminches
« Reply #3 on: 9 Oct 2016, 04:49 pm »
Thanks for that tip. I did not know that.
dminches
« Reply #4 on: 5 Nov 2016, 07:07 pm »
What is learned is that the SP3 doesn't really like having both the single-ended and XLR sub outputs used at the same time.  Any time I muted the SP3 I would get a very loud noise on the single-ended sub.  This was also true when I shut the SP3 off.  This does not happen when I daisy chain them.  I did not try using the AUX-R out.
