0 Members and 1 Guest are viewing this topic. Read 5261 times.
Looking for some advice here. I own the jr's w/ the latest upgrade from Albert. I have thought they would be my end game speaker.I have been interested in these speakers for quite a while as I have bought some equipment from Underwood Hifi that owns the company - http://www.emeraldphysics.com/products/ep-28.I have no experience w/ open baffle design and I am hoping someone may have previously owned them and compared them to VSA's.I would have to sell my current speakers to fund the change, and my pair is the only pair with an upgraded finish b/c of damage during transit. I would never be able to get them back.So, seeking opinions on just sitting tight w/ what I have??? My wife and I just had twins so I don't see myself being able to move up the VSA food chain for quite a while.Thanks for any help -
Jr's are bi amped with prima Luna dialogue 6 mono blocs on tweets / mids, wyred for sound mAmps on the woofers.I also use a DSpeaker to control bass up to 500Hz and I have 2 x 300 W active subs.Speakers are 3 feet from the wall, room sucks since it is an open loft area.We will be building our next house w/in the next 3 years and I will have the ability to build a listening room. This will be a standard bedroom size, maybe 10 x 15 since it will have to serve as my ofifice as well.
Stick to the Jrs, but give them A LOT more space.
Interesting post, since I own the IV jr's and my next upgrade will be speakers. (Not for a while, though, since I just invested in a new amp and preamp -- PS Audio BHK pieces.)In a 10 x 15' room, would you have enough space to get open-baffle speakers sufficiently far from the walls? IIUC they need a lot of distance to sound good.
What do you mean?3 feet from the wall is ideal for my listening space. I know 1 problem is I cannot pressurize the room since it is so open.i do have my subs against the rear wall, any reason to pull them out further?
I have VSA VR 5 Anni's Mk 2.5s (one of the last pair) and have also just purchased PS Audio BHK Pre. It hasn't arrived yet. Wanted to see how you like the pre-amp. What tubes are you using with it?
Since measurement is front of baffle to front wall and the Jrs are almost 2 ft deep, looks like a perfect fit for the rule o' 3rds.
My kids are older now (10, 12) but I had OB mains for the first 8 years of living in this house.They needed to be 3 feet off the front wall for optimal sound. They were DIY efforts. 3x4 foot mdf panels folded slightly with piano hinge. My girls loved playing hide and seek behind them when they were small, and never did rough up anything. My nephews were a different lot. They immediately started yanking wires etc.I think, from a kid perspective, that it really depends on the kids involved. If yours are less prone to monkeying with wiring, and you can live with baffles out in the room OB can be delicious.That said, I currently use boxed speakers, as they provide a significantly better WAF around here. I did have mid sized Maggies for a year, but the cats kept climbing them.If I were you, I would be optimizing those VSA's and enjoy the ride of the twins first 8-10 years.All the best!
Over the years I have had 5 primary listening rooms. The room plays a huge role in how any speaker will sound or can be set up. Without going into specifics, bigger rooms are usually better. And it has been my experience, the more space you can put between any speaker and the walls, the better. 3' isn't what I would call optimal for an OB, to my ears that is the absolute minimum requirement. If you can pull them out 4 - 6 feet away from the front wall, it's worth experimenting. Optimal/precise speaker placement takes a lot of patience and experimentation.
