10 inch Servo Sub
0 Members and 1 Guest are viewing this topic. Read 1472 times.
jimbones
10 inch Servo Sub
« on: 30 Sep 2016, 03:13 pm »
A question for Dan: I'd like to retrofit an existing cabinet that would accommodate a 10 driver and I would like to use your amp. Do you have any 10 inch woofers or are there any drivers that would work with your amp? I assume it cant be any DVC woofer?
Danny Richie
Re: 10 inch Servo Sub
« Reply #1 on: 30 Sep 2016, 03:34 pm »
We currently do not have any 10" servo woofers.
With the 12" woofer only needing 1.8 cubic feet of air space (not much) it allows our 12" woofer cabinet to be smaller than most subs using 10" woofers. And we really gain nothing by going down to a smaller driver.
jimbones
« Reply #2 on: 30 Sep 2016, 06:12 pm »
understood. My baffle width is limited. Can I use a generic DVC with you amp? I would rather use your drivers but.....
Danny Richie
« Reply #3 on: 30 Sep 2016, 11:15 pm »
Technically I believe it will. I'd look only at the HX300 amp for that application.
