Kismet Reference floor standers.
0 Members and 1 Guest are viewing this topic. Read 1998 times.
questz1z
« on: 30 Sep 2016, 01:08 pm »
Does anyone out there know where the crossover network is located in the Kismet Reference floor standers. I have some of the heavy duty Martin Logan threaded, adjustable cones but I would have to drill into the bottom panel to install the inserts. Don't want to drill into the crossover. THANKS in advance for your reply.
Charles Calkins
Re: Kismet Reference floor standers.
« Reply #1 on: 30 Sep 2016, 01:47 pm »
  If Klaus didn't drill and tap the cabinets for spikes or  anything else I wouldn't.
        Cheers
        Charlie
questz1z
« Reply #2 on: 1 Oct 2016, 01:32 pm »
Solved my problem. Got them attached without drilling into the bottom plate. Incredible sounding speakers. The best that I have owned for my setup, and I have owned many.
