0 Members and 1 Guest are viewing this topic. Read 5246 times.
Thanks Scott.What about cryo'd Pass and Seymour 5262A outlets?I can get these for $16/each from Chris at VH Audio.What do you recommend for wire?George
I would use those outlets from Chris. Very good performance for the money.I would use Chris's 12g cryo treated wire & also put a .47uf 600v Auricap on each outlet. Could also put 1 or 2 .47uf 600v Auricaps across hot & neutral at main electrical inlet (inside the Monster conditioner). If you have some ERS cloth around could install on inside top cover. Could also put a Bybee in parallel with each of the hot & neutral main electrical feeds.I have seen that you have a BPT 3.5 signature, may I ask what you are going to use the Monster conditioner for?
are the z-sleeves, ERS tape wrapped around foam?
I also use 2 standard Z-Sleeves along ith Bybee's on my video cables, an excellent way to sharpen up your plasma George. Regards, Robin
Quote from: satfratI also use 2 standard Z-Sleeves along ith Bybee's on my video cables, an excellent way to sharpen up your plasma George. Regards, RobinSatfrat,Are you using the standard Z-Sleeve on a component video cable? If so, is the internal diameter of the sleeve big enough to get the three RCA jacks through at one time? Also would you please tell me a bit more about how the sleeves improved the pic quality.Thanks
