BDP-Pi
0 Members and 1 Guest are viewing this topic. Read 1429 times.
Paul2016
BDP-Pi
« on: 29 Sep 2016, 04:58 pm »
Maybe I'm not seeing the image properly on the Bryston website of the BDP-Pi unit
I see 4 USB inputs, 1 HDMI, 1 Ethernet, 1 Coax, 1 S/PDIF, & 1 Toslink, isn't there a USB out as well for a USB DAC?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP-Pi
« Reply #1 on: 29 Sep 2016, 05:00 pm »
Hi Paul
Yes USB is a two way system so they can be used as either inputs or outputs.
james
Re: BDP-Pi
« Reply #2 on: 30 Sep 2016, 12:43 pm »
Hi James:
I wanted to let you know that I've purchased a BDP-PI (Serial # 00048) from the AudioShop in Kanata.  This unit is to replace my Squeezebox 3 system.
First impressions: Sound is amazing.  I've hooked this up using the coaxial digital output to my Anthem MRX receiver/Bryston 4BST mains.  The one work that comes us to describe the change is "clarity".?
My thanks!
Peter Meyer
Paul2016
Re: BDP-Pi
« Reply #3 on: 25 Oct 2016, 08:49 pm »
Good to hear that you're enjoying it, I'll be going to TAVES over the weekend and hope to have a listen, I've been using my Dell laptop with JRiver but have been considering one of the BDP units. Cheers
