Vincent Audio SA-T8 Balanced Remote Tube Preamplifier- sold
0 Members and 1 Guest are viewing this topic. Read 2033 times.
sbrtoy
For sale is a Vincent SA-T8 tube preamplifier, great reviews including an Editors Choice from Absolute Sound. This unit sounds amazing, transparent and lots of bass impact yet with typical tube sweetness and soundstage.
Uses 12AX7 and 12AU7 tubes, has balanced and single ended ins and outs, unit is in very good shape no nicks or scratches I can find and works perfectly.  Original owner, comes with original boxes, manual, and remote. Sold new for
Near Denver and can arrange pickup during RMAF if you are in town for the show.
More info from Vincent:
Vincent SA-T8 Tube Preamp
Tube complement: Four 12AX7, three 12AU7
Frequency response: 20Hz–50kHz, +/- 0.5dB
Output voltage: 2V
THD: < 0.1 % (1 kHz, 1 Watt)
Input sensitivity: 240mV
Signal/noise ratio: > 90dB
Input impedance: 47k Ohm
Inputs: Four unbalanced on RCA jacks, two balanced on XLR jacks
Outputs: Two unbalanced on RCA jacks, one balanced on XLR jacks, one unbalanced record-out on RCA jacks
Control: Two 12V trigger outputs
Dimensions: 16.9" x 5.3" x 14.6"
Weight: 22 lbs.
« Last Edit: 17 Oct 2016, 01:15 am by sbrtoy »
