13.8 volt okay to replace 14 volt min spec for Aries Mini?
0 Members and 1 Guest are viewing this topic. Read 949 times.
Sonhouse
Folks -
I've got a 13.8 volt, 2.5 amp constant regulated power supply (mainly for 12 volt devices).  It is currently unused.  I'd like to try it in place of the stock Aries
Mini wall wart and save some bucks vs the linear power supply sold by Auralic for $300 bucks.
14 volts/1.2 amp is the lower limit spec from Auralic on the Mini.  16 volts/1 amp is their "standard" spec.
Any thoughts on whether the 0.2 volt lower Pyramid AC/DC unit I have would work? or cause a problem??
Thanks in advance.
