Tubes emit an intermittent ground loop sound
0 Members and 1 Guest are viewing this topic. Read 1904 times.
stump4545
« on: 25 Sep 2016, 05:28 pm »
If tubes in my modwright 36.5 DM pre amp  start to go, do they just die a fiery death, or is it possible that they can emit an intermittent humming ground loop type of sound?
thank you
paul79
Re: Tubes emit an intermittent ground loop sound
« Reply #1 on: 25 Sep 2016, 05:52 pm »
Yes, tubes can hum if they are micro. I can always hear when signal tubes get bad enough, so never experienced a fiery death so to speak. Signal tubes lose focus when they start wearing out, or become noisy or hum. If you are using new production tubes, I would just change them out every couple years or so. Old stock tubes can last a lifetime though, but you will pay for it.
Rectifier tubes can short, open, flash over, etc, but they are typically good and strong until they die. Same for large output tubes.
« Reply #2 on: 25 Sep 2016, 05:54 pm »
Each case is different, there is no a pattern of behavior depends on each tube, quality reliable tubes have a benign death, sound have a change when tube get old.
avahifi
    • http://www.avahifi.com
« Reply #3 on: 26 Sep 2016, 10:33 pm »
The reason very old tubes change sound is because as they age their gain goes down so distortions in the circuit goes up.
No magic, easy to measure with a distortion analyzer.
Frank
Adarsh
« Reply #4 on: 26 Feb 2017, 01:58 pm »
Can you please explain what you mean by "micro"?
