0 Members and 1 Guest are viewing this topic. Read 5066 times.
By the time you reach 320kbps, playback quality is surprisingly good (even more so with the more modern AAC codec).
Often I really note something is wrong when i transfer to CD-R and play,
...I'd rather listen to a cassette.
Your answers only inspire me to ask more questions - so far there is not enough information to formulate a possible solution.Transfer to CD-R? Are you transferring the MP3 as a data file or converting the MP3 to WAV and burning a standard CD audio disk? The MP3 and CD will sound identical because the information is exactly the same.I ask because we need to know what do you play the CD with? A stand alone CD player? A Radio Shack CD player? A DVD player such as an Oppo? The CD player in a computer?What is the computer used to play music? A noisy, harsh, jittery laptop or a smooth, analog sounding music server using linear regulated power supplies and a dedicated audiophile approved USB output card into a stand alone DAC?Played on the latter, a well recorded MP3 can be practically indistinguishable from the CD and much better than any cassette I ever made although at one time audiophiles were recording music on BETA and HI-FI VCR cassettes with excellent results.Wayne
You can also test audio quality by making your own MP3's by ripping a CD that has good sound.Exact Audio Copy (Windows only) with LAME will make MP3's for free. I use dBpoweramp but it is a paid app.Use your test MP3 to compare sound quality, if it sounds good then you are downloading crappy MP3's and you will have to make your own to get the quality you want.But... it sounds like you just want to download and play music without messing with the hardware which equates to sound you are not happy with.So the next solution it to get a better plug and play music box like the Salk Stream player http://www.salkstream.com/ "Add a Tidal subscription and immediately gain the opportunity to add millions of titles to your music library...all seamlessly. It is a wonderful experience."
I have looked for LAME, can't find
SRB I am converting to MP3 in the download, its the source material i see now that is bad
You can sometimes get a higher audio bitrate with a higher resolution video.In the case of MP4 videos, 240p videos will generally have audio bitrates of ~ 64kbps, 360p and 480p videos around ~ 128kbps, and 720p and 1080p videos may have audio bitrates up to 192kbps.If they are YouTube videos they are now limited to ~ 128kbps for any video resolution, at least when using the YouTube player. I don't know what sites you're downloading from or what mechanisms they are employing to deliver an MP3 or AAC audio download from the videos, but it's probably safe to say they are lower audio bitrates and nowhere near a true 320kbps bitrate.Do what WGH suggests and rip a few albums to 320kbps MP3 and use those as a quality baseline.You still don't say what type of computer or player software you're using (it's a bit like pulling teeth!), but if you're using a PC and not using a player like foobar or JRiver Media Center with an ASIO or WASAPI driver to bypass the Windows mixer, then you're resampling and further degrading the source files (iTunes doesn't provide a mechanism to use one of those Windows mixer-bypassing drivers).A DAC using a Burr Brown chip doesn't really describe much as they make a range of DAC chips from under a buck low-spec low-end consumer chips to high-spec high-end audio quality chips, not to mention the varied power supply and analog output stage implementations that are important ingredients in the sound that a DAC actually produces, so it's possible you're leaving some sound quality on the table here as well depending on what you have.Steve
Does your audio equipment and computer have a manufacturer and model number?Or did you build it yourself?An example* of your answers so far:We ask: What car you drive?You answer: It has real big tires.We ask again using different words.You answer: It is fuel injected.*we are not actually asking what car you drive, this is just an example of your responses so far
