0 Members and 1 Guest are viewing this topic. Read 6464 times.
Use high Qts bass woofer with no EQ but sacrifice transient response (bass detail,) or use low Qts bass woofer with added EQ bass boost in your passive crossover.
When you use a low Qts driver and EQ are you not just making it behave like a high Qts driver? The desired SPL curve is the same in both cases.
I don't think it's really behaving the same. The FR might look the same but EQ doesn't affect transient response, while damping does. A high Q driver plays low and loud without EQ by sacrificing mechanical and electrical damping, but when it blends with a more detailed midrange driver the lack of damping can be heard. I personally find high Qts bass drivers in dipole a little bit lacking in tonal texture, ymmv. But it is truly amazing how they can play flat to 30Hz with no box and no EQ!
Great to see some posts from you again. Since the OP has already received some good advice from the community, may I ask what you are working on these days? The last time we spoke, I believe you were thinking of revisiting some type of horn design. Anything in open baffles that has tapped your interest lately?
