N in bottom left corner of screen (BDP-1)
0 Members and 1 Guest are viewing this topic. Read 801 times.
soupcon
« on: 13 Sep 2016, 01:33 am »
forgive me if this is discussed elsewhere, but i'm having a problem where, 2 days after using the unit successfully in my new apt, the unit now shows an N at the bottom left corner of the screen. i can navigate through the tree structure of the 2 usb thumb drives i have attached, but nothing happens when i try to play the files. multiple restarts show the unit in a "cleaning up" operation for a good long time.
any ideas? thanks in advance....
Pundamilia
Re: N in bottom left corner of screen (BDP-1)
« Reply #1 on: 14 Sep 2016, 03:04 am »
I believe that the N indicates a network issue. Are you connected to a network and using a remote tablet or phone application to control the music?
