0 Members and 1 Guest are viewing this topic. Read 5680 times.
The idea, implementation, and improvement are all simple; use two fiber media converters between all your noisy network stuff like routers, NAS, and server (I use the sonicTransporter running Roon Core), and your audio stuff. This way, all that electrical noise from the noisy stuff cannot get into your audio stuff because they are separated by a length of fiber optic cable which does not transmit electrical noise.
It’s safe to say the change in the sound has taken me somewhat by surprise, and I’m now running through some more familiar recordings and hearing – no, not a veil lifting or instruments I never heard before or even an inkier, blacker acoustic backdrop, but rather just music that sounds more real, and makes me want to listen more. And that’s something with which it’s hard to argue.
For now I have an Acoustic Revive LAN noise filter going from the router to the main music server but have put the fiber converter in my Amazon wishlist based on the prior thread as something to consider at some point.
I doubt Wifi will even be an improvement over regular copper RJ-45 with no optical isolation. You are subject to RFI interference coupled with inconsistent speeds and dropouts.
Sure, we all have our opinions, and they're worth listening to, but they vary. For example, Auralic says WiFi "may" sound better than wired, and some of us don't have the problems you mentioned. My modern router is in the next room, and there are no strong signals nearby that would cause RFI. I've tried WiFi vs. wireless, though not in a formal test, and I found no notable differences in sound. The idea that a fiber link (even a short one) can improve sound through isolation is intriguing, and logical if there is really a problem with wired Ethernet. I for one am reluctant to spend ~$150 on spec, especially since I don't hear a problem that needs fixing.It seems to me that the audio press, especially with the addition of online newsletters, has become like cable news. The demand for new content -- new breakthroughs -- is relentless. Judging the significance of what's described is pretty much up to the reader (watcher, listener).
competitorhttp://www.psaudio.com/lanrover-usb-transporter/
