Jotunheim (Schiit)
0 Members and 1 Guest are viewing this topic. Read 7979 times.
JohnR
Jotunheim (Schiit)
« on: 29 Aug 2016, 12:06 pm »
OK so $399 for a fully balanced/differential amp. What do you guys think?
http://schiit.com/products/jotunheim
Re: Jotunheim (Schiit)
« Reply #1 on: 29 Aug 2016, 12:36 pm »
I noted its not dual mono, but its better value than this link (same price) preamp is very useful feature.
http://www.ciaudio.com/products/VHP2
« Last Edit: 29 Aug 2016, 01:58 pm by FullRangeMan »
« Reply #2 on: 29 Aug 2016, 01:23 pm »
Very cool, thanks for the heads up John.
Basically a balanced version of the BiFrost for $100 more with volume control and headphone outputs.  That's just about the perfect desktop solution to go with active/powered speakers.
Wonder now if they'll do a Multi-Bit version, maybe combine the Gungir with Mjolnir 2.  That would be so killer.
brooklyn
« Reply #3 on: 29 Aug 2016, 02:08 pm »
I would love to have an all in one unit like that on my desktop..
I think Schiit has another hit on there hands..
Guy 13
« Reply #4 on: 29 Aug 2016, 02:27 pm »
Several advantages of having all in one unit.
Less cables (Interc and power) smaller unit
and of course price.
Guy 13
on planet Vietnam.
Armaegis
« Reply #5 on: 29 Aug 2016, 03:38 pm »
They haven't explicitly ruled out a multi-bit version, but the modular board space is very tight so it is unlikely at least in the immediate future.
edit: had some wrong information in there
« Last Edit: 13 Oct 2016, 01:40 am by Armaegis »
roscoeiii
« Reply #6 on: 29 Aug 2016, 04:44 pm »
It is mighty impressive that the amp has a low enough noise floor for very sensitive IEMs, but can also drive HE-6s (see Jude's video on HeadFi). Not a lot of amps can say that. And certainly not in this price range.
TF1216
« Reply #7 on: 29 Aug 2016, 07:44 pm »
Don't forget about the iFi-Audio micro iDSD folks.
DAC/Amp with a built-in battery that can also power sensitivity IEMs all the way up to the power hungry HE-6.  :thumb:
roscoeiii
« Reply #8 on: 29 Aug 2016, 07:50 pm »
And of course the Chord Mojo should also be considered along with this and the iDSD Micro. Lots of great options out there!!!
« Reply #9 on: 29 Aug 2016, 11:11 pm »
But the big but, the DAC section of the Jotunheim can be upgraded/swapped out.  And of course it is a balanced design.
K.F.
« Reply #11 on: 12 Oct 2016, 06:08 pm »
I should like to use it with my HD800 but read on a couple of  other forum that the amp is a bit boosted in the treble and there fore is not such a good match.
It also puzzles me that there seems to be no review of any Schiit products on sites like Innerfidelity  and HeadMania.
roscoeiii
« Reply #12 on: 12 Oct 2016, 06:16 pm »
Um, Schiit has most certainly been covered by Inner Fidelity. For example:
http://www.innerfidelity.com/content/schiit-bifrost-digital-analog-converter#kgKexasAtuzYhZYd.97
http://www.innerfidelity.com/content/big-sound-2015-wrap-my-take-headphone-amps#mIY565O2V9gBTFqX.97
JohnR
« Reply #13 on: 17 Oct 2016, 12:05 pm »
Hi, I was thinking about it as an amp only.
Aaanyway... I ended up buying a used Mjolnir 2. Happy as a pig in Schiit. So far.
brooklyn
« Reply #14 on: 17 Oct 2016, 06:51 pm »
At the time of your post, I thought the $399 price was for the whole shebang (dac and amp)..
I do like the idea of a one piece unit serving both functions.. If you throw in the fact that it’s
fully balanced (which is something I would like to have going forward) the Jotunheim makes
for a nice unit for not too much money. I would also like to hookup a pair of powered speakers
at some point which I can’t do with my present setup..
Congratulations on the Mjolnir 2, that Schiit would make me happy to. Do you have it paired with
a Dac? I see on another thread you returned a couple of multibit dac’s..
JohnR
« Reply #15 on: 18 Oct 2016, 07:36 am »
I would imagine the Jotunheim w/ DAC to be a nice combo at the price. But, no personal experience.
The Mjolnir 2 was a bit of a surprise purchase, one just happened to pop up locally... I'm messing about with different DAC boards hanging off SBC streamers (Raspberry Pi and ODroid C1+).
restrav
« Reply #16 on: 17 Feb 2018, 03:08 am »
how do you feel about the mjolnir? im deciding between buying a new jotunheim and  a used mjolnir. sound quality will tip the scale if you have any thoughts to share.
dB Cooper
« Reply #17 on: 17 Feb 2018, 03:34 am »
I have owned a Schiit Modi and a Modi Multibit and been very pleased with both. Schiit products seem to outperform their price points easily. If I were suggesting brands for starting-out or C&C audiophiles, Schiit and NAD would probably be the first ones I'd mention. And many higher-end users would probably like them too, despite the tendency of some hobbyists to label anything affordable as 'mid-fi'.
JohnR
« Reply #18 on: 17 Feb 2018, 03:41 am »
To be honest, I sold it, i found it too large for my desk and decided to go a different path. I liked the MJ2 best with 5670 tubes (and adapter sockets). Also I've realized that all headphones sound better with EQ (once you figure out how to do it) so I now put that as a priority over the amp.
restrav
« Reply #19 on: 17 Feb 2018, 03:50 am »
so you owned MJ2?
i was asking about MJ1.
i was wondering if it sounded any good or not?
ill be using it with Hifiman He400i, with Monolith 1060, amd with Sennheiser HD650. i dont have balanced cables now but id be buying some one for each headphone if i decide to get a mjolnjir. ofcourse it would be so much more economical to go with Jotunheim
