Pioneer PL-A35 Fully-Automatic Belt-Drive Turntable
0 Members and 1 Guest are viewing this topic. Read 1732 times.
jayu969
« on: 24 Aug 2016, 08:49 pm »
Acquired a nice Pioneer PL-A35 from original owner as part of a multi-item purchase however I am not into vinyl.
The player in functional (per the original owner). I did plug it in and turn it on however did not play a record as don't have any.
The cover does have some damage as indicated in the included photos.
LOCAL PICK-UP IN MILWAUKEE,WI AREA.
$140 or best offer.
Description
The PL-A35 combines studio quality performance with the operational ease of a fully automatic.
Simply flick the function lever to the Start position once, and the tonearm will be automatically moved over and lowered onto the record and, at the end of the disc, will return to its rest.
One touch Cue and Repeat features let you interrupt and repeat any record freely.
The platter is driven by a synchronous 4-pole motor of excellent stability independent from power voltage fluctuations.
The belt drive is precision finished on both sides, a feature that helps reduce wow and flutter to an absolute minimum (the tonearm is moved by a separate, geared motor).
Specifications
Type: fully automatic turntable
Drive method: belt drive
Motor: 4-pole synchronous
Speeds: 33 and 45rpm
Speed accuracy: 1%
Wow and flutter: 0.1% WRMS
Signal to noise ratio: 47dB
Platter: 300mm aluminium alloy
Tonearm: static balance type, pipe arm (s-shaped)
Effective length: 221mm
Usable cartridge weight: 4 to 10g
Dimensions: 480 x 415 x 183mm
Weight: 9kg
roscoeiii
Re: Pioneer PL-A35 Fully-Automatic Belt-Drive Turntable
« Reply #1 on: 25 Aug 2016, 03:00 pm »
Tempting...
I am in Chicago.
jayu969
« Reply #2 on: 25 Aug 2016, 03:37 pm »
roscoeii, just PM me if really interested.
