AC Power slave switch
0 Members and 1 Guest are viewing this topic. Read 1353 times.
OTM
« on: 22 Aug 2016, 09:11 pm »
Hello
I am looking for a slave ac switch. I would like to use my B60R to turn on my BDP2, DAC and 4Bsst2 ( using my B60 as a preamp that does not have the 12v trigger)
I know there are modules  available for tools i.e. having a saw turn on a vacuuming system etc.
Any suggestions?
David
jk@home
Re: AC Power slave switch
« Reply #1 on: 23 Aug 2016, 12:21 am »
Check out Xantech, they have different ways to do this.
http://www.xantech.com/Home/
At one time I was using one of their (clamp-on the cord) current sensing setups to power up a Juice Goose power sequencer, to turn on multiple power amps. Worked great.
OTM
« Reply #2 on: 23 Aug 2016, 02:34 am »
Thank you, I just had a look and that should give me a couple of options.
Regards
David
