$0LD:SURGE-X XR315 Surge Eliminator/Pwr Cond Industries Best? price drop to $439
0 Members and 1 Guest are viewing this topic. Read 1980 times.
mooncrikit
Offering for your consideration a "as new" pristine condition SURGE-X XR-315. Very conservatively rated a 9/10 due to age only, but truly is a 10/10. Includes rack ears (never used or mounted, set of four brand new aluminum case footers (I used different isolating ones which are NOT included). I am the original owner who purchased this marvelous unit on 7-22-14. I am upgrading to another SURGE-X model. Fees and CONUS shipping included at my offer price of $599.00,
price $0LD at $399.00!!!
8 Industrial Grade outlets. 15 Amp capacity
• Dimmable display provides system data at your fingertips
• Improves Audio and Video Performance
• Features include Advanced Series Mode surge elimination, Impedance Tolerant Noise Filtration, In Rush Current Elimination
• Proudly made by hand in USA with best-in-class 10 year warranty
A sophisticated home theater or computer system setup can easily cost thousands of dollars and just as easily be destroyed or damaged by a power disturbance. Safeguard your investment with Surge-X professional-grade residential AV protection.
Surge-X products are engineered to properly protect high end audio and home theater equipment from AC surges and electrical transients that can disrupt sound quality and digital performance. Our Advanced Series Mode technology is completely non-sacrificial and eliminates surge energy up to 6,000 Volts, without producing harmful side effects such as ground contamination or common-mode disturbances.
We are the only manufacturer in the industry providing professional-grade power protection and intelligence solutions for rack systems, branch circuits, and standalone equipment.
Specifications
Operational Voltage Range: 90 to 150 Volts AC
Current rating: 15 Amps
Power Rating: 1,800 Watts
Maximum Load Inrush Energy: 1400 Joules total during power-up
Surge Let-through Voltage: Zero let-through Voltage for a 6000 Volt surge
Meets Federal Guidelines: Grade A, Class 1, Mode 1 (CID A-A-55818)
EMI/RFI Filter, Normal Mode: 40 dB @ 100 KHz, 50dB @ 300 KHz, 50 dB @ 3 MHz, 50 dB @ 30 MHz (50 Ohm load)
EMI/RFI Filter, Common Mode: 18dB @ 300 KHz, 30 dB @ 1 MHz, 50 dB @ 5 MHz, 50 dB @ 20 MHz (50 Ohm load)
Maximum Applied Surge Voltage: 6,000 Volts *
Maximum Applied Surge Current: Unlimited (due to current limiting) *
Maximum Applied Surge Energy: Unlimited (due to current limiting) *
Endurance: (C62.41-1991 category B3 pulses), 1 KV > 500,000; 3 KV > 10,000; 6 KV > 1000
Number of Outlets:8,
Dimensions (no rack ears or feet): 17.3” W x 10.5” D x 1.7” H
Weight: 12 lbs (5.4kg)
Temperature Range: 5C to 35C
Humidity Range: 5% to 95% R.H. Non-condensing
Agency Listings: ETL and cETL (UL 1449, Third Edition, Type 3 Surge Protective Device; UL 1283; CSA C22.2 No.8-M1986, R2004)
*1.2 x 50 microsecond industry standard combination wave surge as per IEEE C62.41
Includes:
original shipping box, rack ears, aluminum cabinet feet, manual
« Last Edit: 13 May 2017, 05:31 pm by mooncrikit »
Charles Xavier
It must be me
rpf
JerryM
  • Where's The Bar?
It's me, too...  :?
TEA FOR ONE
If you have to ask,you can't afford it!
thunderbrick
  • I'm just not right!
News to me. :scratch:
audiogurujax
What is the Price???
By the Forum rules all sales ads must have a price.
mooncrikit
price added, sorry for the oversight...thanx for the comments!
« Last Edit: 27 Sep 2016, 08:56 pm by mooncrikit »
mooncrikit
price drop SALE! $439.00!!!
« Last Edit: 14 Jan 2017, 05:59 pm by mooncrikit »
