Cheapo projector advice gents.....
0 Members and 1 Guest are viewing this topic. Read 3026 times.
EDS_
« on: 11 Nov 2004, 07:21 pm »
Hola,
My bias is DLP. But I will consider other mechanisms.
Desires.....
1. $1,500-$2,000 budget HDTV, 16:9, etc.
2. Room can be made reasonably dim during the day but not totally dark.
3. Room is 12.5X18.
To be frank I know so little about projectors I'm not sure what questions I should ask.
Thx,
Ed
PS-I'm really big into sports. Are other means (plasma, DLP & LCD TVs etc.) better for sports?
Christof
« Reply #1 on: 11 Nov 2004, 10:25 pm »
Check out the reviews at AVSforum.  The decision b/t Infocus X1, Screenplay 4805 & SP 5000 loomed in my head for a long time.  I finally bought the X1 based on the fact that it is an excellent starter PJ, or so I've been told.   I use mine on a 16:9 screen in 16:9 mode with no problem.  Picture is great even in dim light.  Great buy at just under $800 if you can still find one.
Have you ever viewed a front projection system?  Do you notice rainbows, if so you might want to look at the SP5000 which I'm nearly positive is an LCD.
c.
Rob Babcock
« Reply #2 on: 12 Nov 2004, 12:12 am »
I'll also proffer my now-standard recommendation of the Piano DLP projector from Plus Corp.  I've used one for a couple years to great satisfaction.  It's only capable of 480p, so it's not HD.  But you can buy them now for under a grand.  However, I do suggest to try to audition some DLP projectors before you buy.  I don't see the Rainbow Effect (ie "color separation artifacts"), but those who do often find it unbearable.
zybar
« Reply #3 on: 12 Nov 2004, 12:57 am »
Spend towards the top of your budget and get the Panny 700.
You can read all about it over at www.projectorcentral.com or www.avsforum.com.
George
pekar
« Reply #4 on: 5 Dec 2004, 03:04 pm »
Benq pb6200, see avs thread.
If you watch in the daytime, though, a projector may not be your best option.
You'll get some washout trying to compete with the sun.
Ears
« Reply #5 on: 16 Dec 2004, 09:44 pm »
I have had the x1, currently have the 4805 and I am almost ready to get the Panasonic ae 700.
I am waiting on a few issues like the flashing issue to have a fix before buying though.
The 4805 has worked flawlessly whith 700 hours so its hard to just get rid of it for a 720p pj that seems to have an issue or two.
Greg
FAR
« Reply #6 on: 21 Dec 2004, 07:37 am »
I think AE 700 out performs 4805, you can watch closer, and have less screen door effect. I sat 10 feet away from the screen and saw no SD effect, but for 4805, even 15 feet away, I could still notice SD effect.
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #7 on: 21 Dec 2004, 07:54 am »
I would go with the Panny 700 as it offers a long throw range (20ft) and is easy to mount with some horizontal/vertical adjustment as well as some other nice features.
plus it has a great picture, screen door effect is zero unless you sit way too close and well just go check one out locally.
We've got a place here that just hooks two projectors up vis-a-vis a switcher and then they put a piece of wood in front of one project to block it out...then they do it to the other one so you get a real good idea on the spot of the differences between projectors.
good luck and have fun!
nathanm
« Reply #8 on: 21 Dec 2004, 04:35 pm »
Isn't the "screen door effect" easily fixed by simply defocusing the lens a little?  Cause that's basically what your eyes are doing anyway the further you move back.
Andrikos
« Reply #9 on: 21 Dec 2004, 05:01 pm »
EDS, if you're going to watch sports in the day with a little ambient light, that's ok. Sports are bright and they will look pretty good in the day.
For a perfect movie experience, think "Movie Theater": dark.
Dark walls, dark ceilings, dark wall coverings, dark carpets, no direct to the screen lighting etc. etc.
Any DLP will look good in your setup. I don't think anybody has recommended the Optoma H30 here so I will. Look for "guitarman" in AVS. He started a MONSTER H30 thread in the <$3,500 PJ AVS forum.
Good luck with your choices.
PS What are you planning to use as a screen?
I'd recommend the Dalite Model B Hi Power with CSR in the 85"-90" range. Cheap, bright and great for some ambient light rejection. Also, retractable to get it ot of the way.
Andrikos
« Reply #10 on: 21 Dec 2004, 05:08 pm »
Quote from: nathanm
I wouldn't call it "fixed" but rather "masked".
The screen door is always there as high frequency noise.
LCD's have much higher "noise" than DLP or LCoS because their fill ratio (~50%)  is so much smaller than either of the other techs (88%-90% DLP, 90%-93% LCoS).
Also, LCDs have [VB] vertical banding (most objectionable for me) which also shows up as screendoor. This form of fixed pattern noise [FPN] is inherent to LCD technology...
Russtafarian
  • Typical reaction to the music I play
« Reply #11 on: 21 Dec 2004, 05:42 pm »
I've been out of the loop on projectors since I picked the legendary NEC LT150 three years ago.  1024 x 768, 800 lumens and 1000:1 contrast ratio for $2500.  I'm throwing it 15 feet to a 120" 4:3 high gain Dalite screen.  Watched HD MNF on it last night and it still looks great, though I would like deeper blacks for movies.
Where are we at in the budget projector world these days?  Do we simply have LT150 performance for a few hundred less or do we have a significant jump in performance for the same money?
I'm thinking that my next front projector will be native 1080p, 2000 lumens, and 3000:1 contrast ratio for under $2k.  Are we getting close to that or am I just deluded?
Russ
« Reply #12 on: 21 Dec 2004, 05:52 pm »
I think we'll see something like that in the next 2 years, although the 1080p will be in higher priced projectors for a while before trickling down to low priced ones.  The rest doesn't seem to far off at all.
Andrikos
« Reply #13 on: 21 Dec 2004, 06:15 pm »
Quote from: Russtafarian
Yes, you are deluded...  :wink:
Ok, get this:
Fujitsu just came out with a 1080p LCD with inferior lumen and contrast specs than what you're "dreaming" of for the tidy sum of $25,000!!!  :o
I don't think anybody has one yet, but it shouldn't be long...
It'll take 3 years, at least, for 1080p FP to be in the under $5k range, never mind $2k. 10 years perhaps?
