Sub pre out on the HD-AVP
0 Members and 1 Guest are viewing this topic. Read 3170 times.
sac8d4
« on: 8 Aug 2016, 12:27 am »
Anyone familiar with the NuPrime HD-AVP's sub pre out? Can anyone comment on if the sub pre out can be configured to be active with 2.0 content?
John Casler
Re: Sub pre out on the HD-AVP
« Reply #1 on: 8 Aug 2016, 01:24 am »
Here is the "simple answer".  Found in the FAQ's
sac8d4
« Reply #2 on: 8 Aug 2016, 02:16 am »
Thanks John....I thought I read it somewhere but I couldn't remember where.
sac8d4
« Reply #3 on: 19 Aug 2016, 08:05 pm »
John,
Since you have had experience with both the Nuforce MCP-18 and the NuPrime HD-AVP, I am interested in hearing your thoughts on how the analog paths compare sonically?
Sac8d4
John Casler
« Reply #4 on: 19 Aug 2016, 08:16 pm »
John,
Sac8d4
The NuFORCE MCP-18 was a spectacular performer for the price.  As you know, it was "pure analog".
The HD AVP has far more functionality including the DAC, Server/Streamer Capability, Surround Processing, and Bass Management.
It is so good, we used it as the PREAMP (for 2 channel) at THE SHOW last June.
I have not heard them side by side to compare, but I doubt the HD AVP would blow the MCP-18 away, but would think that side by side it would sound better, overall.
I should also mention that the HD AVP does have a USB input, that runs a PURE PATH 2 channel signal (no bass management) to a pair of ANALOG outputs for what would surely be better than the MCP-18 with an outboard DAC.
rustydoglim
« Reply #5 on: 22 Aug 2016, 10:06 am »
The HD-AVP has packed too many features and ended up making it difficult to sell. Our loss is your gain and with reduced price (40% discount) of $1395, it is a "steal".
supernaut77
« Reply #6 on: 31 Aug 2016, 07:34 pm »
Just to be extra clear, is the subwoofer output active also when the usb-audio input is used? I think it is unclear when reading the FAQ:
http://www.nuprimeaudio.com/index.php/products/faq-prod.html#faq_6
What is the difference between Pure Direct, Pure Audio, and USB Audio?
Pure Direct and Pure Audio modes are part of the multi-channel mode and utilize the high quality multi-channel DAC. USB Audio goes through a separate high performance stereo DAC board.
Pure Audio is a 2-channel Stereo mode where multi-channel inputs from the source are converted to 2 channel audio. Pure Direct is a pass-through (from the source device such as BluRay player) mode without any EQ effect.
Don't confuse Pure Audio or Pure Direct with USB Audio input. If you have a computer connected to HD-AVP through USB Audio, by selecting the USB Audio as input source you will be utilising the high-end stereo DAC (this USB Audio DAC has the same performance as NuPrime DAC-10) instead of the multi-channel DAC for surround sound decoding.
The L&R outputs from 7.1 outputs come from USB DAC outputs or AVP outputs. The USB L&R outputs come only from the USB DAC.  That means if you are using USB Audio as the input, there are two sets of outputs: L&R outputs from 7.1 outputs and USB L&R outputs. This allow you to setup a separate high-end stereo system in another room. Therefore, if you select USB Input as the source, then the USB DAC outputs go to 7.1 L&R RCA and XLR and USB L&R outputs.
chrisc
  • Listen to the great composers
« Reply #7 on: 26 Sep 2016, 11:58 am »
Yes, the sub works on all inputs, including USB
However, it sends the full bandwidth to the sub, not just low frequencies.  I managed to suppress all signals above 120Hz on a Yamaha sub, but if you connect a regular amp and spkrs to the sub out, you hear the full range.  Altering the paramaters on the menu has no effect
rustydoglim
« Reply #8 on: 27 Sep 2016, 05:16 pm »
The sub is full range when the input is USB. That's because the USB audio has the DAC-10 board (minus a few other things such as analog and digital preamp) and it is independent of the AV decoding board.
