Cartridge Replacement
0 Members and 1 Guest are viewing this topic. Read 2315 times.
Phil_S
« on: 7 Aug 2016, 11:59 pm »
It's that time again to replace the cartridge. As usual funds are tight. In the interest of full disclosure here's my turntable/cartridge history over the past 10 years.
Turntable is a Technics 1200 Mk3 with the KAB Fluid damper & Cardas rewired tonearm, with the thick rubber mat. I started with a Grado Black, transitioned to an AT 120e, and am currently running an AT 125LC. Same body as the 120e, just a replacement stylus.
I'd like to keep the cost sub $300. Obviously I am not considering a moving coil, moving magnet/iron are my best bets.
In your experience, what are my best bets?
JDUBS
Re: Cartridge Replacement
« Reply #1 on: 8 Aug 2016, 12:54 am »
The KAB ProS Cartridge w/STY30 Stylus would be a very solid choice.  I regret selling mine.
-Jim
neobop
  • BIRD LIVES
« Reply #2 on: 8 Aug 2016, 03:17 am »
OR..........
You could get an ATN150MLX before they're gone.  The MLX has been discontinued and that stylus on your body is fantastic.  A boron/nude microridge for $250 (Lp Gear) is a real bargain.  New TOTL is a deluxe version of your body with a tapered AL/nude shibata.  The stylus is about the same money as the MLX.
Never heard the KAB/Ortofon.  Might be really good.  Getting rid of the headshell is a plus, but you can't change alignment.
neo
ACHiPo
« Reply #3 on: 8 Aug 2016, 07:47 pm »
+1 on the AT 150 MLX.  I picked up the whole cartridge for less than $300.  It's taken me some getting used to as it's the first MM cartridge I've had in many many years, but it sounded pretty darned good with the Wavestream Kinetics phono stage I demo'd this weekend.  I still prefer the Lyra Delos and Kleos, but those are ~10x the cost.
djEmpire
« Reply #4 on: 17 Aug 2016, 06:32 pm »
AT 150 is a giant killer.
AgentOrange
« Reply #5 on: 2 Sep 2016, 12:08 am »
A high end cart is not always the place to spend money.
Lots of guys I know have a cart better than their system can handle.
I would place cart replacement low on the list unless you have an exceptional audio line all other places.
orientalexpress
« Reply #6 on: 2 Sep 2016, 02:52 pm »
The guy looking for a $300.00 cartridge ,What are you talking about?
Dieterle Tool
  • I don't know what it is, but I wunt it.
« Reply #7 on: 2 Sep 2016, 03:41 pm »
The cartridge has got to be the most significant link in the TT chain.  :duh:
The Audio Technica ML150 is a great option for sub $300 range (probably the best). But I guess I will be the first to suggest a Denon 103. Although I have no experience with mounting one on a Technics table, I know Technics provides a 4 gram weight to accommodate its rigid cantilever.
Dieter
