Audio/Video Gear and Systems
The Discless Circle
toddbagwell
Roon remote issue
Roon remote issue
0 Members and 1 Guest are viewing this topic. Read 1124 times.
mca
Roon remote issue
7 Aug 2016, 03:01 pm »
I have been using and enjoying Roon for a while now, never had any issues in the past. Yesterday I fired my system up and found that Roon remote on my iPad now refuses to connect. I think Roon did some kind of update on Friday, but not sure what would have changed to stop it from working. Anyone else have this problem?
mca
Re: Roon remote issue
8 Aug 2016, 02:55 pm »
Anyone have any ideas on what to try? I'm running Roon on a Musicvault running Windows 10. I did check the firewall and it's turned off.
ebag4
GO CARDS!!!
Reply #2 on:
8 Aug 2016, 05:31 pm »
I have a different setup, but not experiencing any issue with Roon. When I run into a connection error I typically start rebooting each piece of equipment in the chain, including my router and my iPad .
Best,
Ed
mca
Reply #3 on:
8 Aug 2016, 11:02 pm »
I shut everything that has to do with the system and restarted with no luck.
The Discless Circle
toddbagwell
Roon remote issue
