Quick interconnect question
0 Members and 1 Guest are viewing this topic. Read 1534 times.
floresjc
« on: 30 Jul 2016, 04:10 pm »
I have an audio interface I'm using as my PC's sound card essentially. I use an Ultra EC preamp attached to it, TRS out from the interface to RCA on the preamp.
In the interface software I have three choices of Line levels for the outputs: Monitor, Line +4, and Line -10. I spent half of last night screwing around because I didn't realize that the Monitor setting was active, and I had extremely low output.
Using the +4 or -10 seems to match levels much better and provides much more output. Is one "more safe" or "better" than the other? I think generally +4 is considered for "pro" hookups and -10 for "consumer", but I really don't know where those distinctions come from.
Lefty052347
  • AVA Associate
Re: Quick interconnect question
« Reply #1 on: 30 Jul 2016, 04:41 pm »
If you are using the EC for volume control, I would suggest the setting that gives you a normal (80-85db) listening level in the 10-2 o'clock position with the volume control.  That allows for more low level settings.
Dean
floresjc
« Reply #2 on: 30 Jul 2016, 05:00 pm »
Wayner
« Reply #3 on: 30 Jul 2016, 05:01 pm »
I would use the -10 setting so that the device does not over-drive the input board.
'ner
