Thiel CS 1.6 w/Outriggers St Louis Mo pickup B-P-T SC-7.5LNT speaker cables incl
0 Members and 1 Guest are viewing this topic. Read 1592 times.
vintage9594
I have a good condition pair of Thiel CS1.6 speakers finished in dark rosewood/cherry finish.
These have the optional outrigger support bases.
Description: Two-way, magnetically shielded, floorstanding loudspeaker. Drive-units: 1" (25mm) aluminum-dome tweeter, 6.5" (165mm) metal-cone woofer with 3" voice-coil. Crossover frequency: 3kHz. Crossover slopes: first-order, 6dB/octave. Frequency response: 50Hz-20kHz, ±2dB. Phase response: ±10 degrees maximum. Sensitivity: 90dB/W/m. Nominal impedance: 4 ohms, 3 ohms minimum. Recommended Power: 50-300W.
Dimensions: 35.5" (902mm) H by 9" (229mm) W by 11.5" (292mm) D. Weight: 38 lbs (17.3kg) each.
Read more at http://www.stereophile.com/content/thiel-cs16-loudspeaker-specifications#IvgkqOKfGtdxo7Gi.99
I am located in St Louis Mo and these are for local pickup only as I do not have the boxes for them.
$900 obo.
Will Include a pair of Balanced Power Technologies SC-7.5LNT speaker cables that retailed for $499.00 6ft pair with spades.
text for photos to 314-498-3115
thanks
« Last Edit: 29 Aug 2016, 03:38 am by vintage9594 »
vintage9594
Re: Thiel CS 1.6 w/Outriggers St Louis Mo pickup open to offers
« Reply #1 on: 6 Aug 2016, 02:19 am »
Bump...open to offers for local pickup.
vintage9594
Bump
Lowered price and will include a pair of Balanced Power technologies speaker cables with speakers.
thanks
vintage9594
Bump for $900 local pickup
