Bryston Bdp-1 has no internet connection
0 Members and 1 Guest are viewing this topic. Read 6919 times.
Vittorio
« on: 24 Jul 2016, 07:28 am »
I have a problem with my BDP 1, after installing the first release of manic moose me the message appears: BDP has not internet connection.
I am days that I try to solve the problem but I can not, can someone help me.
Thank you in advance
« Last Edit: 26 Jul 2016, 03:08 pm by Vittorio »
vonnie123
Re: Bryston Bdp-1 has not internet connection
« Reply #1 on: 24 Jul 2016, 11:48 pm »
Boot up the BDP-1, and identify the local IP address displayed on the front screen.  Can you connect to the BDP-1 via your home LAN (IP address)?  If so, Try to re-install the firmware via your PC/MAC.
Vittorio
« Reply #2 on: 25 Jul 2016, 08:08 am »
Hello vonnie123,
If I go into the modem settings on bdp - 1 appears among the devices connected to the network , I also tried to reinstall the firmware but the situation does not change .
Marius
« Reply #3 on: 25 Jul 2016, 08:16 am »
Hello vonnie123,
This message "no internet connection' also shows while updating the database. Did your Bryston BDP finish updating the Database? You have to let the BDP finish and settle before everything works as it should.
Can you reach your BDP via the web browser and address bryston-bdp-1.local ?
On the frontpanel of the BDP you can use the up/down buttons to find the IP address of the BDP. What is showing?
Marius
unincognito
    • bryston.com
« Reply #4 on: 25 Jul 2016, 07:15 pm »
which version of the firmware is currently installed?
Vittorio
« Reply #5 on: 25 Jul 2016, 07:29 pm »
Marius
Hello Marius ,
the missing connection message remains even after the database update , I can reach the bdp by entering the IP address which displays the bdp awfull with the buttons up and down, I would like to update the bdp for ROON.
Vittorio
Vittorio
« Reply #6 on: 25 Jul 2016, 07:33 pm »
The installed firmware is  S2.05 07/11/2014
vonnie123
« Reply #7 on: 25 Jul 2016, 09:25 pm »
Current version is S2.28 / 6-28-2016
I would contact Bryston, and/or work with unincognito (Chris) to update your device.
unincognito
    • bryston.com
« Reply #8 on: 25 Jul 2016, 10:38 pm »
That version should be new enough to update without intervention, but if you find your unable to update you should place the BDP into service mode and email me the service id.
http://www.bryston.com/PDF/Manuals/BDP-2_MM_Manual.pdf
Marius
« Reply #9 on: 26 Jul 2016, 07:44 am »
Hello Marius ,
Vittorio
Seems your BDP does have its correct ip address. I recognize the message being somewhat mystifying now and then, while the network is working as it should. Most of the time some patience makes all the difference. Not to worry, it will work out fine.
Do as Chris suggests, enable service mode, and have Chris fiddle with your BDP ;) he'll get it online and updating in no time .
Marius
Vittorio
« Reply #10 on: 26 Jul 2016, 03:07 pm »
The bdp not even enter into the service mode , you get a message that tells me that it is impossible to connect to the client .  :banghead:
Vittorio
« Reply #11 on: 26 Jul 2016, 03:08 pm »
Marius
the bdp not even enter into the service mode , you get a message that tells me that it is impossible to connect to the client .  :banghead:
vonnie123
Re: Bryston Bdp-1 has no internet connection
« Reply #12 on: 26 Jul 2016, 06:12 pm »
Looks like Chris (unincognito) is on vacation for a week.  CALL BRYSTON, and ask them for assistance.  If they can get you in contact with Gary Dayton, he is pretty good with the BDP-1.
Vittorio
« Reply #13 on: 27 Jul 2016, 07:35 am »
Thanks for the suggestions , how do I contact Gary Dayton?
Vittorio
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #14 on: 27 Jul 2016, 12:02 pm »
Vittorio
[email protected]
james
Vittorio
CanadianMaestro
« Reply #16 on: 27 Jul 2016, 06:45 pm »
Vittorio,
Have u tried this yet --
Go into MPAD on your mobile control device. Open it up. BDP-1 powered up. Wireless router on.
Go to Settings at the top -- the bulls-eye symbol.
Try directly typing in the IP address e.g. 102.72.0.103.  Find out what the IP address is for your router -- easily done from your desktop.
I've had to do this a few times way back when, and I have no more issues (I use Loony Loon).
Good luck,
Pete
Vittorio
« Reply #17 on: 29 Jul 2016, 11:29 am »
Problem solved! I contacted Gary Dayton, after making a screen sharing pointed out to me that the problem had to be in the modem which was blocking access to the Internet. I contacted my fixed-line operator that re-established the internet connection of the BDP-1.
Thank you all for your contributions and suggestions!
Vittorio
vonnie123
« Reply #18 on: 30 Jul 2016, 06:59 pm »
Awesome.  :D
