0 Members and 1 Guest are viewing this topic. Read 10155 times.
RedNet is Focusrite’s flagship range of modular Ethernet-networked audio interfaces that harnesses the power of Audinate’s tried and tested Dante digital audio networking system to bring studio quality sound to any modern audio application. Fundamentally RedNet is an extremely scalable, near zero latency audio distribution systemRedNet 3 can be used simply as a means of converting 32 channels of audio and delivering it somewhere else on the network at near-zero latency... Directly to your computer’s Ethernet port using a standard Ethernet cable (and “Dante Virtual Soundcard”)
—Important information—RedNet 1, 2, 3, 4 and 5 devices which are currently running Dante software version 3.4.x are not discovered in RedNet Control 1.8 or 1.9. These devices must be updated to Dante software version 3.7 first.
Your devices will be running Dante software 3.4.x if you have not updated beyond RedNet Control 1.4 (released Q1 2015). To verify this, open Dante Controller, double click on a device to open device view, then select “Status”. In the Dante Information box there will be a number beside “Software Version”. If this reads 3.4.x you will need to proceed with the update procedure below.
—Update Instructions—1. Download Dante Firmware Update Manager: https://www.audinate.com/products/firmware-update-manager2. Install and run Dante Firmware Update Manager3. Select the network interface used for Dante connections and press next4. Ensure all relevant Dante devices are powered up. We recommend powering down all devices that do not require this update.5. Click “Update Dante Firmware”6. Click “Browse” and navigate to “RedNet-3.4-to-3.7.dnt” supplied in the zip7. Select “Override Device Matching” and click Next. Dante Controller will then search for the relevant devices.8. Tick the box(es) on the left for the device(s) you need to update and click “Start”9. The firmware update(s) will now be performed. When the update(s) are complete, a message will be displayed. Click “OK” and power cycle the devices.10. The devices will now be discoverable in RedNet Control 1.8 and 1.9. RedNet Control will then perform another firmware update ensuring the latest firmware is on the device.
Good morning. Thank you very much for the how-to. Got a Rednet 3 Wednesday and have done all the software installations and flash upgrades. Only using a single ethernet connection from my music dedicated mac mini i7 (Mavericks), but get orange triangles in the speaker/output settings in the Dante Controller and can't get sound . I'll call Focusrite later, but in the interim, if you wouldn't mind, a quick question, please.What are your settings in the Rednet Control under the little wrench pull-down menu on the front of the Rednet GI ? Leaving aside the sample rate setting, I'm particularly interested in the other settings, including the rednet/off selections in one of the drop-down menus. Thanks for your time. Cordially,
Thanks very much. Your response and one email to Focusrite has things working and playing well together. Replaces a fairly complicated usb chain and sounds quite a bit better. Appreciate the help. Cordially,
Good morning. My USB setup was music dedicated mac mini i7>>wireworld starlight usb (sometimes with audioquest jitterbug, sometimes without)>>Regen Amber>>F-1 XMOS USB digital interface>>s/pdif>>TacT 2.2x (DAC/room correction)>>aes/ebu>>TacT 2170 (digital amp)>>Spatial Hologram M2 Turbos.Now it's music dedicated mac mini i7>>CAT 6 ethernet>>Focusrite Rednet 3>>S/pdif>>Tact, etc.In my former USB setup, the USB chain improvements ranked as follows, in my system. The Regen made a noticeable improvement. The F-1 XMOS was a much bigger improvement than just the Regen (~2x, if I was forced to quantify). The Rednet 3 jumped way up over the F-1 (almost an order of magnitude seeming progression). Never could make up my mind about the jitterbugs (used two at times). If I had to pick two adjectives to describe the music I'm hearing through the Rednet, I'd say "liquid" and "organic."Again, very much appreciate your help and I heartily suggest others give it a try. Now I have to figure out what to do with all of my old usb stuff. Cordially,
