TASCAM DA-45HR DAT Deck - 16/24 Bit Support - Sold
0 Members and 1 Guest are viewing this topic. Read 2776 times.
Stimpy
« on: 20 Jul 2016, 12:00 am »
TASCAM DA-45HR DAT Deck - 16/24 Bit Support - (Almost) New!  -  (Central, VA)  -  Sold
Capable of both 16 bit and 24 bit recording and playback.  Selectable sampling rates of 44.1 KHz or 48 KHz.
Purchased as a back-up DAT Deck for a private mastering studio. Only tested for proper functionality and stored since. ZERO record hours on heads! Awesome piece for a home recording studio. Retail price of $1999 when introduced, and valued at $2200 when discontinued.
Link to manual:
http://tascam.com/content/downloads/products/292/DA-45HR_manual.pdf
Reviews:
http://www.soundonsound.com/sos/feb99/articles/tascamda45428.htm
http://www.sweetwater.com/publications/sweetnotes/sn-latefall98/page02.html
DA-45HR OVERVIEW
The DA-45HR builds on the feature set from the DA-40, and brings the machine into the 24 bit recording realm.
The DA-45HR is the world's first 24-bit DAT recorder. It is capable of writing full 24 bit, high resolution data to the standard DAT tape. This allows you to have an affordable, simple solution for 24 bit recording.
The DA-45HR can also serve as a standard 16 bit DAT solution, reading and writing DATs created on standard DAT machines.
Since the DA-45HR can serve as both a 16 bit and 24 bit DAT recorder, it can be installed in place of a standard 16 bit DAT recorder. You don't need two separate machines to have dual functionality.
Another helpful feature is the Word Clock I/O on the DA-45HR. Word Clock In and Thru allow you to clock to an external source on playback. This is key for integration into larger digital set-ups with a central clock source.
As mentioned, the DA-45HR implements the same advanced functions that the DA-40 offers, including track names, locate points, single play, selectable SCMS status, parallel and serial control, and calibrated I/O.
DA-45HR SPECIFICATIONS:
Records 24 Bit Stereo In High Resolution Mode
Records and Plays Standard 16 Bit DAT Format
Balanced XLR & Unbalanced RCA Analog I/O
AES/EBU and SPDIF Coax Digital I/O
Word Sync In/Thru
Headphone Output w/ Level Control
(2) Locate Points
Single Play Function (Play One Track & Pause)
Loop Play Function (Between Locate Points)
Large Jog Shuttle Wheel
Parallel Control Port
Serial Control In
Selectable SCMS Status
Optional RC-D45 Wired Remote
3-U Rack Mountable DAT Recorder
Record Mute Function
Supports Track Names in DAT Sub codes
Margin Counter w/ Reset Function
Calibrated Input Switch
Output Attenuation on XLR Outputs
24 Bit A/D, 20 Bit D/A Converters
Thanks for looking!
« Last Edit: 22 Jul 2016, 02:07 pm by Stimpy »
Stimpy
Re: TASCAM DA-45HR DAT Deck - 16/24 Bit Support - $399
« Reply #1 on: 22 Jul 2016, 05:24 am »
My TASCAM DAT deck seems to be available again.  It sold, but the buyer hasn't paid.  I'll continue to wait, and give them a few more days.  I want to be fair.  But, after that, it's up for grabs!  Thanks again.
