Removing cloth on VR-3
0 Members and 1 Guest are viewing this topic. Read 3222 times.
erikullvin
« on: 19 Jul 2016, 06:51 pm »
Hello,
 I have a pair of VR-3s where the right one have started distorting (buzzing) in the bass. The sound appears from around the woofer but is a higher frequency than the woofer would play. It stops if i push down on the cloth an inch or so above the woofer.
 It does not look like the suspension is bad when I shine a light through and I have not got many ideas what it could be.
My thought is that I need to remove the sock to see what's up.
How do I go about this? Remove it from the top or bottom?
 Erik
danabunner
Re: Removing cloth on VR-3
« Reply #1 on: 21 Jul 2016, 02:50 pm »
Can't help you.  I've owned my VR-4s for 20 years and have never attempted to remove, or even move, the sock.  Have no idea of how to do that.  Only times I've ever seen my drivers is when I shine a flashlight through the sock.
JackD201
« Reply #2 on: 23 Jul 2016, 12:24 am »
VR-3s? Either but if you're afraid you might knick the top cap, turn them over and do it from the bottom ;)
erikullvin
« Reply #3 on: 30 Jul 2016, 04:47 pm »
Thanks for your replys.
 I sent a mail to Albert Von Schweikert and got some clues as to what it could be, but when I pulled the cloth down the noise subsided. I wonder if it could be that the sock has become stretched a bit so it vibrates against the wood when I'm nearing high volume?
leif8660
    • Von Schweikert Audio
« Reply #4 on: 31 Jul 2016, 06:10 pm »
Try stretching the cloth tight and see if it goes away
Delacroix
« Reply #5 on: 21 Aug 2016, 06:55 pm »
Erik-- any update?
erikullvin
« Reply #6 on: 22 Aug 2016, 07:24 am »
Hello,
  The problem seems to have ceased when the cloth was pulled away and put back. We'll see if it returns.
 / Erik
Delacroix
« Reply #7 on: 22 Aug 2016, 10:20 pm »
Excellent - if only everything worked like that!
