0 Members and 1 Guest are viewing this topic. Read 23629 times.
I am still not done with the Denon, so I still have to give honors to the Sony. I will have the Denon done in time for CES however.Thanks,Dan
The 3910 used at CES will actually be auctioned off along with most of the gear that we show with, including a Sony 999ES with Platinum mods and at least one of our new SWL 9.0SE preamps. This will all take place at Audiogon. They are having a special auction for mfrs. showing at CES.Thanks,Dan
I really like the 3910 and do prefer it to the 2900. Relative to the 5900, I prefer the simpler stock analog stage and I believe the DSP is superior. The 5900 is a fantastic unit and I honestly can't say that the 3910 is better. I am not modifying the 5900 any longer however, due to the time and complexity involved in the work.I will have the 3910 details, pricing and availability posted this week I expect.Thanks,Dan
The SS mod that we have developed for the unit can be adapted to MCH, but could be costly, as we are using high-quality audio transformers as part of the circuit re-design. We can just upgrade op-amps and improve parts in the signal path for less $, but the transformer design is REALLY exceptional sounding .Dan
No problem. It will have the new outboard supply enclosure - looks nicer and is larger, hence roomier for us to work.I expect to finallize the work this next week, so I will let you know what your options are and how it ends up. It is already pretty maxed out in terms of options, but I will let you know if anything new comes up.Thanks,Dan
