spatial audio m3 or m4
ric
« on: 10 Jul 2016, 04:43 pm »
Hi, was wanting to know if anyone has any updates on their experience with these, as I'm so tempted to bite the bullet. Also, any comments on the smaller M4 vs. the M3 in a smaller room, thanks!
JerryM
  • Where's The Bar?
Re: spatial audio m3 or m4
« Reply #1 on: 10 Jul 2016, 07:09 pm »
CSI
« Reply #2 on: 10 Jul 2016, 08:24 pm »
I've had my M4's for about 6 weeks. They sound terrific in my small and difficult room (10' x10'). I have an ACI subwoofer available but, so far, haven't felt the need to hook it up. I'd say if you have a largish room go with the M3's. If not, the M4's will do the trick. They will play quite loudly and the bass is so clean and accurate you may not miss the slight bottom end extension. The highs will be the same since they are identical above 800 Hz but the larger woofers in the M3's will move a bit more air. There are great reviews out there on both models.
Phil A
« Reply #3 on: 10 Jul 2016, 08:41 pm »
Welcome to AC!
TrungT
« Reply #4 on: 10 Jul 2016, 08:53 pm »
Welcome to AC  :thumb:
« Reply #5 on: 10 Jul 2016, 09:11 pm »
Greetings & Welcome to AC ric   :thumb:
Guy 13
« Reply #6 on: 10 Jul 2016, 11:42 pm »
A warm welcome to AudioCircle Mr. Ric.
Guy 13
zybar
« Reply #7 on: 11 Jul 2016, 12:15 am »
Ric,
Welcome to AC.
One of the links JerryM provided is the thread I started on my M3 Turbo S speakers.
Unless your room is really small, I would lean towards getting the M3's.
Either way, killer speaker and a smoking deal!!
George
